メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Vtech InnoTab 3S Motherboard Replacement
必要な工具と部品
    1. Vtech InnoTab 3S Motherboard Replacement, Rear Panel: 手順 1、 3の画像 1 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: 手順 1、 3の画像 2 Vtech InnoTab 3S Motherboard Replacement, Rear Panel: 手順 1、 3の画像 3
      • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
      • Remove the batteries from the device.
      FixBotに聞いてみる
      コメントを追加
    2. Vtech InnoTab 3S Motherboard Replacement: 手順 2、 2の画像 1 Vtech InnoTab 3S Motherboard Replacement: 手順 2、 2の画像 2
      • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Vtech InnoTab 3S Motherboard Replacement: 手順 3、 3の画像 1 Vtech InnoTab 3S Motherboard Replacement: 手順 3、 3の画像 2 Vtech InnoTab 3S Motherboard Replacement: 手順 3、 3の画像 3
      • Using a nylon spudger, remove the five caps that hide the screws.
      • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
      • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
      • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
      FixBotに聞いてみる
      コメントを追加
    4. Vtech InnoTab 3S Motherboard Replacement: 手順 4、 1の画像 1
      • Carefully remove the rear panel from the front panel of the device.
      • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
      FixBotに聞いてみる
      コメントを追加
    1. Vtech InnoTab 3S Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Vtech InnoTab 3S Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
      • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
      • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
      • Remove the six 3 mm screws securing the battery clip.
      FixBotに聞いてみる
      コメントを追加
    2. Vtech InnoTab 3S Motherboard Replacement: 手順 6、 1の画像 1
      この手順で使用する道具:
      • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
      • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
      • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Karina Garcia
メンバー登録日: 08/30/15
878 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S8G2
4 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 35
今までの合計 973
