メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Visioneer OneTouch 7400 USB Scanner Bed Replacement
必要な工具と部品
    1. Visioneer OneTouch 7400 USB Scanner Bed Replacement, Outer Case: 手順 1、 1の画像 1
      • On the bottom of the scanner, remove the screw at the top left side.
      FixBotに聞いてみる
      コメントを追加
    2. Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 2、 2の画像 1 Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 2、 2の画像 2
      • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
      • Remove the screw beneath the foot-pad.
      FixBotに聞いてみる
      コメントを追加
    3. Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 3、 3の画像 1 Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 3、 3の画像 2 Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 3、 3の画像 3
      • Rotate the scanner so the screw hole is located on the top left hand side.
      • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
      • Gently pry the two casements apart beginning above the screw hole and working your way around.
      • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
      FixBotに聞いてみる
      コメントを追加
    4. Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 4、 1の画像 1
      • Separate the two casement pieces.
      FixBotに聞いてみる
      コメントを追加
    1. Visioneer OneTouch 7400 USB Scanner Bed Replacement, Scanner Bed: 手順 5、 1の画像 1
      • Apply even pressure against the back of the glass while securing the plastic frame in place.
      FixBotに聞いてみる
      コメントを追加
    2. Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 6、 2の画像 1 Visioneer OneTouch 7400 USB Scanner Bed Replacement: 手順 6、 2の画像 2
      • With consistent pressure on the glass, move your fingers down the sides until the glass is no longer stuck to the double-sided tape.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jena
メンバー登録日: 10/18/13
608 ポイント
6のガイドは作成済み
チーム
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013人のメンバー
UMAINE-DIAZ-F13S1G13
3 メンバー
19のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 575
