メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Viola String Replacement
    1. Viola String Replacement, String: 手順 1、 1の画像 1
      • Turn the tuning peg belonging to the string you want to replace.
      • Pegs on the left side (C, G) of the viola require you to turn clockwise to loosen, and pegs on the right side (D, A) turn counterclockwise to loosen.
      • Make sure to turn the peg in the correct direction. Accidentally tightening the strings too much may cause it to snap.
      FixBotに聞いてみる
      コメントを追加
    2. Viola String Replacement: 手順 2、 2の画像 1 Viola String Replacement: 手順 2、 2の画像 2
      • Gently remove the string from the scroll side of the viola, then remove the opposite side of the string from the fine tuner area.
      FixBotに聞いてみる
      コメントを追加
    3. Viola String Replacement: 手順 3、 1の画像 1
      • Insert the new string into the peg hole.
      • Make sure the hole is in the correct area and that the inserted string does not overlap other strings. For example, the C string hole should be to the left of the G string.
      FixBotに聞いてみる
      コメントを追加
    4. Viola String Replacement: 手順 4、 1の画像 1
      • Turn the tuning peg slowly to tighten the newly inserted string.
      • If the string has a coloured tip, turn the peg until all the colour is wound up.
      • Do not worry about snapping the string in this step. The ball side of the string has not been inserted so there is no risk.
      FixBotに聞いてみる
      コメントを追加
    5. Viola String Replacement: 手順 5、 2の画像 1 Viola String Replacement: 手順 5、 2の画像 2
      • Insert the ball side of the string into the fine tuner area. If the string does not reach, loosen the tuning peg until it slides in easily. Make sure to also align the string with the bridge.
      FixBotに聞いてみる
      コメントを追加
    6. Viola String Replacement: 手順 6、 2の画像 1 Viola String Replacement: 手順 6、 2の画像 2
      • After the string has been inserted, begin slowly tuning the string by turning the pegs.
      • Try to tune a pitch lower using the pegs, then use the fine tuners to fully tune the string.
      • Be careful, the string may snap if tightened too much. Try using the advice above to avoid this.
      FixBotに聞いてみる
      コメントを追加
    7. Viola String Replacement: 手順 7、 1の画像 1
      • Gently tug the newly inserted string to make sure it is secured. If it slides off the bridge, it is not tightened enough.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Irene Shang Yun Yang
メンバー登録日: 05/24/23
145 ポイント
1ガイドが承認済み
チーム
York University, Team A-9, Allen Summer 2023 York University, Team A-9, Allen Summer 2023人のメンバー
YORK-ALLEN-SU23SAG9
3 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 652
