メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Verizon Ellipsis 8 Disassembly
必要な工具と部品
  1. Verizon Ellipsis 8 Disassembly, Power Down and Remove Sim Card: 手順 1、 1の画像 1
    この手順で使用する道具:
    • Open SIM card flap and remove SIM card. Use a pair of tweezers to get the SIM card out.
    FixBotに聞いてみる
    コメントを追加
  2. Verizon Ellipsis 8 Disassembly, Remove Rear Cover: 手順 2、 1の画像 1
    • Use a guitar pick to open the cover of the tablet. For most effective results, start at the corner of the tablet and continue.
    • **BE SURE NOT TO DAMAGE THE SIM CARD OR SD CARD SLOTS**
    FixBotに聞いてみる
    コメントを追加
  3. Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 手順 3、 2の画像 1 Verizon Ellipsis 8 Disassembly, Rear Cover Removal Cont.: 手順 3、 2の画像 2
    • Continue opening the cover now using a metal spudger and wiggle it to pry the cover open.
    • You can look at the picture of the rear cover to see where the snaps are located.
    FixBotに聞いてみる
    コメントを追加
  4. Verizon Ellipsis 8 Disassembly, Remove Battery: 手順 4、 1の画像 1
    • Remove the screws attached to the circuit board on the battery using a Phillips 00 screw head and remove the battery.
    • There was no adhesive on the back of the battery, just along the sides.
    FixBotに聞いてみる
    コメントを追加
  5. Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 手順 5、 3の画像 1 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 手順 5、 3の画像 2 Verizon Ellipsis 8 Disassembly, Remove Ribbon Cables and Smaller Circuit Boards: 手順 5、 3の画像 3
    • Be careful when removing the ribbon cables as there is adhesive on the back of them. To remove the cables flip up the rear part of the connector to slide the cable out - *gently*.
    • The USB Charging Connector and the Antenna Board both have adhesive on the back. Remove the screws and carefully lift up on the boards to remove them.
    • **Be careful with the antenna cable!**
    FixBotに聞いてみる
    コメントを追加
  6. Verizon Ellipsis 8 Disassembly, Remove Mainboard & Speaker: 手順 6、 1の画像 1
    • Remove the 5 screws holding the Mainboard and Speakers in to place. *One of the screws is under the ribbon cable*
    • There was no adhesive holding this board in and the whole assembly lifted out as one piece.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
31 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
SMcC21985
メンバー登録日: 11/10/15
1,271 ポイント
2のガイドは作成済み
4件のガイドコメント
Keith Brockley - 返信 共有
what size screws are thoze i need to get some i lost some
stacy - 返信 共有
My tablet is on, when I press to Open , it doesn't do anything
Gladys Lockhart - 返信 共有
My tablet is on working, when I press to get is frozen, it doesn't let me in
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 74
今までの合計 21,328
