メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech Safe and Sound DM111-2 Baby Unit Motherboard replacement Guide
必要な工具と部品
  1. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Baby Unit Motherboard replacement Guide: 手順 1、 1の画像 1
    • Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 2、 2の画像 1 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 2、 2の画像 2
    • Using the plastic spudger gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
    • Unlike the parent unit there are no wires across the two housing pieces, so once the latches are undone simply pull it apart without worry of disconnecting anything.
    FixBotに聞いてみる
    コメントを追加
  3. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 3、 2の画像 1 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 3、 2の画像 2
    • Once apart the motherboard will be exposed with two 4mm phillips head screws near the top and 4 wires leading leading to a circuit board hidden under the motherboard.
    • Remove the two screws near the top of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  4. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: 手順 4、 2の画像 1 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: 手順 4、 2の画像 2
    • Remove the strip of adhesive tape located under the motherboard.
    • Gently lift the motherboard to expose the inner components.
    • Use a spudger to scrape away the adhesive and foam connecting the microphone.
    • Unscrew the 4mm phillips head screw holding the microphone in place.
    FixBotに聞いてみる
    コメントを追加
  5. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 5、 3の画像 1 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 5、 3の画像 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: 手順 5、 3の画像 3
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Before de-soldering, check to see no scorching or broken connections appear on the wires, power supply jack or antenna.
    • De-solder the connections from the motherboard using a soldering iron and a solder sucker.
    • De-solder the connections to the microphone, located on the bottom left of the mother board.
    • De-solder the 4 wires connecting the LED board to the motherboard.
    • De-solder the antenna's solder joint, located above the microphone wire connection.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Jean Carlos
メンバー登録日: 08/31/15
201 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015人のメンバー
USFT-REMMELL-F15S6G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 32
今までの合計 1,311
