メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech InnoTab 2 Camera Replacement
必要な工具と部品
  1. VTech InnoTab 2 Camera Replacement, Battery: 手順 1、 3の画像 1 VTech InnoTab 2 Camera Replacement, Battery: 手順 1、 3の画像 2 VTech InnoTab 2 Camera Replacement, Battery: 手順 1、 3の画像 3
    • Apply slight pressure and slide the button above the battery cabinet to the right to open.
    • Remove battery cabinet cover by sliding away from the center of device.
    • This device requires 4AA batteries to function without the AC adaptor.
    FixBotに聞いてみる
    コメントを追加
  2. VTech InnoTab 2 Camera Replacement, Back Panel: 手順 2、 3の画像 1 VTech InnoTab 2 Camera Replacement, Back Panel: 手順 2、 3の画像 2 VTech InnoTab 2 Camera Replacement, Back Panel: 手順 2、 3の画像 3
    • Remove all nine plastic caps from the back of the device using the plastic opening tool.
    • These covers are made of hard plastic so they may be difficult to remove.
    FixBotに聞いてみる
    コメントを追加
  3. VTech InnoTab 2 Camera Replacement: 手順 3、 3の画像 1 VTech InnoTab 2 Camera Replacement: 手順 3、 3の画像 2 VTech InnoTab 2 Camera Replacement: 手順 3、 3の画像 3
    • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
    • Be careful not to apply excessive force.
    • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  4. VTech InnoTab 2 Camera Replacement: 手順 4、 2の画像 1 VTech InnoTab 2 Camera Replacement: 手順 4、 2の画像 2
    • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
    • Do not use excessive force while removing the screws to prevent damaging the plastic case.
    FixBotに聞いてみる
    コメントを追加
  5. VTech InnoTab 2 Camera Replacement: 手順 5、 2の画像 1 VTech InnoTab 2 Camera Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, detach the back plate from the front piece.
    • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
    • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
    FixBotに聞いてみる
    コメントを追加
  6. VTech InnoTab 2 Camera Replacement, Camera: 手順 6、 3の画像 1 VTech InnoTab 2 Camera Replacement, Camera: 手順 6、 3の画像 2 VTech InnoTab 2 Camera Replacement, Camera: 手順 6、 3の画像 3
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection to the camera is located on top side of the devices motherboard.
    • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
    • Attach the replacement camera and lower the latch until a click sound can be heard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Roberto Valdes
メンバー登録日: 10/18/17
302 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S1-G85, Cagle Fall 2017 USF Tampa, Team S1-G85, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G85
2 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 661
