メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VHS Shell Replacement
必要な工具と部品
    1. VHS Shell Replacement, Plastic Shell: 手順 1、 2の画像 1 VHS Shell Replacement, Plastic Shell: 手順 1、 2の画像 2
      • Unscrew the five 3mm screws with the Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. VHS Shell Replacement: 手順 2、 1の画像 1
      • Once the screws are out, pull off the front of the VHS shell.
      • Take off any labels on the sides of tape before doing this step.
      • Make sure you are taking off the front of the shell, otherwise the reels or other loose pieces may fall out.
      FixBotに聞いてみる
      コメントを追加
    3. VHS Shell Replacement: 手順 3、 2の画像 1 VHS Shell Replacement: 手順 3、 2の画像 2
      • Hold down on the white lever.
      • While holding down, carefully take out the reel on the right.
      • Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
      FixBotに聞いてみる
      コメントを追加
    4. VHS Shell Replacement: 手順 4、 2の画像 1 VHS Shell Replacement: 手順 4、 2の画像 2
      • Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
      • If you are unable to buy an empty VHS shell, you can also use one that already has a tape in it, just you would have to repeat step 3 to take out the reel.
      FixBotに聞いてみる
      コメントを追加
    5. VHS Shell Replacement: 手順 5、 1の画像 1
      • Once the screws are out, pull off the front of the replacement shell.
      FixBotに聞いてみる
      コメントを追加
    6. VHS Shell Replacement: 手順 6、 1の画像 1
      • Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
      • Make sure that the reel is placed in so that any excess tape not in the reel is hanging out of the top (like pictured in step 8).
      FixBotに聞いてみる
      コメントを追加
    7. VHS Shell Replacement: 手順 7、 1の画像 1
      • Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
      FixBotに聞いてみる
      コメントを追加
    8. VHS Shell Replacement: 手順 8、 1の画像 1
      • Turn the reels to retract any excess tape hanging out of the top.
      • This isn't a necessary step, just one that I prefer to do.
      FixBotに聞いてみる
      コメントを追加
    9. VHS Shell Replacement: 手順 9、 1の画像 1
      • Place the top of the replacement shell back on.
      FixBotに聞いてみる
      コメントを追加
    10. VHS Shell Replacement: 手順 10、 1の画像 1
      • Screw the screws back in with a screwdriver.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
McKinley Hixon
メンバー登録日: 03/19/21
202 ポイント
1ガイドが承認済み
チーム
2件のガイドコメント
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
handlenyc - 返信 共有
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 120
今までの合計 3,971
