メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Using the 3DS's Safe Mode
  1. Using the 3DS's Safe Mode, Booting safe mode: 手順 1、 1の画像 1
    • Ensure the console is powered off
    • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
    • Keep these buttons held down until the console boots in the next step
    • While still holding the other buttons, press the power button
    FixBotに聞いてみる
    コメントを追加
  2. Using the 3DS's Safe Mode, Updating the System: 手順 2、 3の画像 1 Using the 3DS's Safe Mode, Updating the System: 手順 2、 3の画像 2 Using the 3DS's Safe Mode, Updating the System: 手順 2、 3の画像 3
    • You should boot into a "system update" screen. Click OK and accept the prompts
    • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
    FixBotに聞いてみる
    コメントを追加
  3. Using the 3DS's Safe Mode: 手順 3、 1の画像 1
    • When the update finishes, the console will automatically turn off
    FixBotに聞いてみる
    コメントを追加
終わりに
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
darth mango
メンバー登録日: 03/13/23
3,748 ポイント
3のガイドは作成済み
4件のガイドコメント
Does this work on old family 3ds?
maxxy waxxy - 返信 共有
Works on every 3ds and 2ds model
darth mango - 返信 共有
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - 返信 共有
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
darth mango - 返信 共有
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 110
過去 30 日: 464
今までの合計 15,692
