メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Unresponsive keyboard fix
必要な工具と部品
  1. Unresponsive keyboard fix, Remove the bottom cover: 手順 1、 1の画像 1
    • Note: These 2 screws are longer then the others.
    • Unscrew the remaining 8 screws. These are all the same length.
    FixBotに聞いてみる
    コメントを追加
  2. Unresponsive keyboard fix, Remove the battery: 手順 2、 1の画像 1
    • Remove the back cover. There are no warranty stickers that need to be broken.
    • Locate the keyboard connector. It is covered with a piece of tape helping hold it in place. This tape often fails after a certain amount of time.
    • You may need to remove the battery to disconnect it. Unscrew the 3 screws holding the battery in the system.
    FixBotに聞いてみる
    コメントを追加
  3. Unresponsive keyboard fix, Reconnect the keyboard: 手順 3、 1の画像 1
    • Note: New tape should be added once reseated.
    • Remove the tape covering the connector.
    • Here on the picture you can see the connector in the unlocked position. These hold the connector in and should be completely pushed in.
    • Push the connector in. Do this until it is secure.
    • Lock the tabs that retain the keyboard connector in place.
    FixBotに聞いてみる
    コメントを追加
終わりに
Screw everything back and if you've done it right, enjoy all your keyboard keys again.
キャンセル: このガイドを終了できませんでした。
96 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Francis
メンバー登録日: 11/29/12
1,784 ポイント
1ガイドが承認済み
63件のガイドコメント
Awesome fix, thanks! This exact issue was plaguing the up and down keys on my UX31 (this is after having to RMA the thing for power issues). Be forewarned, if you are attempting this on a machine that is in sleep or hibernation mode, it has the potential to shut it off, with no visible LED lights to indicate. You can reset by holding down the power button for ~10 seconds and it should boot back up, if not, check connections again.
The LED light on the charging cable is a decent indication if something's up or not.
Jeff L - 返信 共有
Yep, this worked on my zenbook UX31A. The two white push tabs have to be fully in for the wires in the ribbon cable to contact. When u push in one, the other one pops open, so push both together.
Also, MY zenbook needed a torx T4 to unscrew the screws.
spud - 返信 共有
Great fix! My shift keys were not registering, and upon removing the back I saw the keyboard connector was indeed loose. Securing it in place fixed the problem. Thanks a lot!
Adolfo Brandes - 返信 共有
Thanks for this! I had random keys unresponsive at various times, my white connector was plugged in on one side but not the other. See-sawed it back and forth until they were both in.
I think the cause is the battery; it physically places the keyboard cable under stress. I replaced the tape with much stronger stuff but am not sure if it will be a permanent fix...
Jonathan - 返信 共有
Thanks man, you are the best!! This is a great notebook, and this problem was starting to make me hate it. Easy as cake. Wish you good fortune and the best of luck.
Saturnin Kepa - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 113
今までの合計 177,649
