メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ukulele String Replacement
必要な工具と部品
  1. Ukulele String Replacement, Ukulele String Replacement: 手順 1、 1の画像 1
    • Prepare by gathering all of the things you'll need: your ukulele, the new string, a pair or scissors, a sharpened pencil, a cloth, a string winder (optional), and a tuner or tuning app. Make sure you purchase the right sized strings.
    • Remove the old string by untying it from the bridge.
    • Unwind the string with its tuning peg.
    FixBotに聞いてみる
    コメントを追加
  2. Ukulele String Replacement: 手順 2、 1の画像 1
    • Clean the ukulele with a paper towel or cloth. Make sure to clean around the bridge and the tuners.
    FixBotに聞いてみる
    コメントを追加
  3. Ukulele String Replacement: 手順 3、 1の画像 1
    • The next step is to smooth run the strings. Use a sharpened pencil to add a little graphite to the indent where the string will lie. This helps the string slide smoothly through the slot.
    FixBotに聞いてみる
    コメントを追加
  4. Ukulele String Replacement: 手順 4、 3の画像 1 Ukulele String Replacement: 手順 4、 3の画像 2 Ukulele String Replacement: 手順 4、 3の画像 3
    • Tie-up the string to the bride of the Ukulele. Begin by sliding one end of the string through the holes on the bridge. Then wrap it around itself, as shown in the image. Make sure that it is snug against the bridge.
    • With the excess string, wrap it under the string once, and then twice. This will prevent the string from slipping.
    • Finally, to make it anchored, pull the string tightly into place.
    FixBotに聞いてみる
    コメントを追加
  5. Ukulele String Replacement: 手順 5、 3の画像 1 Ukulele String Replacement: 手順 5、 3の画像 2 Ukulele String Replacement: 手順 5、 3の画像 3
    • Put the end of the string through the hole in the tuning peg, and tightly wrap the string around the peg three times.
    • If it is wrapped more than three times, it may interfere with tuning, and less than three times could make it less secure.
    • Next, turn the tuning peg until there is tension in the string. This process can be sped up by using a string winder. Then snip off the excess string with a scissors.
    FixBotに聞いてみる
    コメントを追加
  6. Ukulele String Replacement: 手順 6、 1の画像 1
    • The final step is to tune your ukulele. Although this can be done by ear, you may find it easier to use a tuner or a tuning app.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Bekah Klemp
メンバー登録日: 09/19/18
154 ポイント
1ガイドが承認済み
チーム
University of Minnesota, Team S1-G6, Card Fall 2018 University of Minnesota, Team S1-G6, Card Fall 2018人のメンバー
UMN-CARD-F18S1G6
3 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 36
今までの合計 1,659
