メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
USB/Auxiliary Port
必要な工具と部品
    1. USB/Auxiliary Port, Outer Case: 手順 1、 2の画像 1 USB/Auxiliary Port, Outer Case: 手順 1、 2の画像 2
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      FixBotに聞いてみる
      コメントを追加
    2. USB/Auxiliary Port: 手順 2、 1の画像 1
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      FixBotに聞いてみる
      コメントを追加
    3. USB/Auxiliary Port: 手順 3、 1の画像 1
      • Slide out the rubber foot located on the bottom of the case.
      FixBotに聞いてみる
      コメントを追加
    4. USB/Auxiliary Port: 手順 4、 1の画像 1
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      FixBotに聞いてみる
      コメントを追加
    5. USB/Auxiliary Port: 手順 5、 3の画像 1 USB/Auxiliary Port: 手順 5、 3の画像 2 USB/Auxiliary Port: 手順 5、 3の画像 3
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      FixBotに聞いてみる
      コメントを追加
    1. USB/Auxiliary Port, USB/Auxiliary Port: 手順 6、 2の画像 1 USB/Auxiliary Port, USB/Auxiliary Port: 手順 6、 2の画像 2
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      FixBotに聞いてみる
      コメントを追加
    2. USB/Auxiliary Port: 手順 7、 1の画像 1
      • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      FixBotに聞いてみる
      コメントを追加
    3. USB/Auxiliary Port: 手順 8、 3の画像 1 USB/Auxiliary Port: 手順 8、 3の画像 2 USB/Auxiliary Port: 手順 8、 3の画像 3
      この手順で使用する道具:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      FixBotに聞いてみる
      コメントを追加
    4. USB/Auxiliary Port: 手順 9、 1の画像 1
      • Remove the 5mm T6 screw holding the port assembly onto the end cap.
      • Unlike the flat top screw holding the metal housing, these screws are roundtop.
      FixBotに聞いてみる
      コメントを追加
    5. USB/Auxiliary Port: 手順 10、 1の画像 1
      • Remove the old port assembly from the end cap.
      • Alternate Reassembly required, read on.
      FixBotに聞いてみる
      コメントを追加
    6. USB/Auxiliary Port: 手順 11、 1の画像 1
      • Disconnect the Motherboard connection ribbon from the motherboard.
      • The ribbon should no longer be connected at either end.
      FixBotに聞いてみる
      コメントを追加
    7. USB/Auxiliary Port: 手順 12、 1の画像 1
      • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
      FixBotに聞いてみる
      コメントを追加
    8. USB/Auxiliary Port: 手順 13、 1の画像 1
      • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
      • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
      FixBotに聞いてみる
      コメントを追加
    9. USB/Auxiliary Port: 手順 14、 2の画像 1 USB/Auxiliary Port: 手順 14、 2の画像 2
      • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
      • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
      FixBotに聞いてみる
      コメントを追加
    10. USB/Auxiliary Port: 手順 15、 2の画像 1 USB/Auxiliary Port: 手順 15、 2の画像 2
      • Reconnect the button ribbon connector on the top of the port assembly.
      FixBotに聞いてみる
      コメントを追加
    11. USB/Auxiliary Port: 手順 16、 2の画像 1 USB/Auxiliary Port: 手順 16、 2の画像 2
      • Reconnect the endcap to the plastic housing.
      • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
      FixBotに聞いてみる
      コメントを追加
    12. USB/Auxiliary Port: 手順 17、 1の画像 1
      • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
      • Finish reassembling in descending order starting at step 5.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow steps 1 through 5 in reverse order.
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Noah Sadler
メンバー登録日: 04/01/15
548 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G1
5 メンバー
27のガイドは作成済み
1件のガイドコメント
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 58
今までの合計 15,972
