メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Turtle Beach Elite Pro Right Speaker Replacement
必要な工具と部品
    1. Turtle Beach Elite Pro Right Speaker Replacement, Ear Cushion: 手順 1、 1の画像 1
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      FixBotに聞いてみる
      コメントを追加
    2. Turtle Beach Elite Pro Right Speaker Replacement: 手順 2、 2の画像 1 Turtle Beach Elite Pro Right Speaker Replacement: 手順 2、 2の画像 2
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      FixBotに聞いてみる
      コメントを追加
    3. Turtle Beach Elite Pro Right Speaker Replacement: 手順 3、 2の画像 1 Turtle Beach Elite Pro Right Speaker Replacement: 手順 3、 2の画像 2
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      FixBotに聞いてみる
      コメントを追加
    1. Turtle Beach Elite Pro Right Speaker Replacement, Right Speaker: 手順 4、 1の画像 1
      • Remove the right ear cushion.
      • The right ear piece does not have any additional attachments.
      FixBotに聞いてみる
      コメントを追加
    2. Turtle Beach Elite Pro Right Speaker Replacement: 手順 5、 1の画像 1
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      FixBotに聞いてみる
      コメントを追加
    3. Turtle Beach Elite Pro Right Speaker Replacement: 手順 6、 2の画像 1 Turtle Beach Elite Pro Right Speaker Replacement: 手順 6、 2の画像 2
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      FixBotに聞いてみる
      コメントを追加
    4. Turtle Beach Elite Pro Right Speaker Replacement: 手順 7、 1の画像 1
      • Cut the two wires that are attached to the speaker.
      • Cut the wires as close to the speaker as possible. These wires will be used in the next step.
      FixBotに聞いてみる
      コメントを追加
    5. Turtle Beach Elite Pro Right Speaker Replacement: 手順 8、 2の画像 1 Turtle Beach Elite Pro Right Speaker Replacement: 手順 8、 2の画像 2
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alexis Uribe
メンバー登録日: 03/24/17
528 ポイント
4のガイドは作成済み
チーム
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017人のメンバー
BU-WILLIAMS-S17S5G1
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 28
今までの合計 1,297
