メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Turtle Beach Elite Pro Left Speaker Replacement
必要な工具と部品
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Ear Cushion: 手順 1、 1の画像 1
      • Firmly pinch ear cushion between thumb and forefinger.
      • Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
      • If the black rubber lining on the orange plate is grasped, then the rubber lining on the ear piece may tear.
      FixBotに聞いてみる
      コメントを追加
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 2、 2の画像 1 Turtle Beach Elite Pro Left Speaker  Replacement: 手順 2、 2の画像 2
      • Rotate ear cushion counter-clockwise about half an inch.
      • The ear cushion should audibly snap out of place.
      • After it has audibly snapped out of place, lift the ear cushion off of the device.
      • During reassembly, rotate the ear cushion clockwise.
      FixBotに聞いてみる
      コメントを追加
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 3、 2の画像 1 Turtle Beach Elite Pro Left Speaker  Replacement: 手順 3、 2の画像 2
      • Using the new cushion, align the pegs located on both the orange plate and ear cushion.
      • Make sure that both the ear cushion and the orange plate have the same designation.
      • Once the pegs are aligned, push the new ear cushion in place.
      FixBotに聞いてみる
      コメントを追加
    1. Turtle Beach Elite Pro Left Speaker  Replacement, Left Speaker: 手順 4、 1の画像 1
      • Remove the left ear cushion completely from the headset.
      • The left ear cushion will be on the side of the headset where the microphone and audio control is attached.
      FixBotに聞いてみる
      コメントを追加
    2. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 5、 2の画像 1 Turtle Beach Elite Pro Left Speaker  Replacement: 手順 5、 2の画像 2
      • Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
      FixBotに聞いてみる
      コメントを追加
    3. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 6、 2の画像 1 Turtle Beach Elite Pro Left Speaker  Replacement: 手順 6、 2の画像 2
      • Use the opening tool to separate the orange plate from the black base plate.
      • Focus on the wires that are connected to the speaker.
      FixBotに聞いてみる
      コメントを追加
    4. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 7、 1の画像 1
      • Using wire cutters, cut the two wires that are attached to the speaker.
      • Make sure to cut the wires as close to the speaker as possible, because these wires will be used in the next step.
      FixBotに聞いてみる
      コメントを追加
    5. Turtle Beach Elite Pro Left Speaker  Replacement: 手順 8、 2の画像 1 Turtle Beach Elite Pro Left Speaker  Replacement: 手順 8、 2の画像 2
      • Replace the old speaker with the new speaker.
      • Using the soldering iron, solder the wires to the new speaker.
      • Make sure to solder the wires to their original locations on the speaker.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alexis Uribe
メンバー登録日: 03/24/17
528 ポイント
4のガイドは作成済み
チーム
Baylor, Team S5-G1, Williams Spring 2017 Baylor, Team S5-G1, Williams Spring 2017人のメンバー
BU-WILLIAMS-S17S5G1
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 32
今までの合計 3,669
