メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Trunk LED Tailgate Strip Light Installation
必要な工具と部品
  1. Trunk LED Tailgate Strip Light Installation, Cleaning: 手順 1、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Cleaning: 手順 1、 2の画像 2
    • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
    • Use soap and water to scrub the area clean since that place is normally dirty.
    FixBotに聞いてみる
    コメントを追加
  2. Trunk LED Tailgate Strip Light Installation, Mounting time: 手順 2、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Mounting time: 手順 2、 2の画像 2
    • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
    • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
    • Straighten the LED strip and peel adhesive.
    • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
    FixBotに聞いてみる
    コメントを追加
  3. Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 1 Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 2 Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 3
    • Tap reverse light wire.
    • You will need to remove either side of the tail light to locate the reverse light.
    • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
    FixBotに聞いてみる
    コメントを追加
  4. Trunk LED Tailgate Strip Light Installation, Find the connector: 手順 4、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Find the connector: 手順 4、 2の画像 2
    • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
    • You will find the trailer light connector near the tow hitch.
    FixBotに聞いてみる
    コメントを追加
  5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 1 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 2 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 3
    • Hide the wires or zip-tie them.
    • Check the trunk LED tailgate lamp to make sure everything works.
    FixBotに聞いてみる
    コメントを追加
終わりに
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,600 ポイント
23のガイドは作成済み
21件のガイドコメント
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - 返信 共有
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 - 返信 共有
Anyone have the answer to this problem yet?
Trevor G - 返信 共有
I'm having the same problem!
Richie - 返信 共有
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 104
今までの合計 44,498
