メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Trek 4300 Bicycle Front Reflector Replacement
必要な工具と部品
  1. Trek 4300 Bicycle Front Reflector Replacement, Loosen the Reflector: 手順 1、 1の画像 1
    • Stand facing the front of the bike, bracing the front wheel between knees.
    • Using a Phillips-head screwdriver, loosen the screw holding the reflector in place.
    FixBotに聞いてみる
    コメントを追加
  2. Trek 4300 Bicycle Front Reflector Replacement, Remove Bracket: 手順 2、 2の画像 1 Trek 4300 Bicycle Front Reflector Replacement, Remove Bracket: 手順 2、 2の画像 2
    • Remove the screw. Bracket should now be able to rotate freely around the handlebar.
    • Separate the flat pieces of the bracket creating about a 1" gap.
    • Push the bracket away from you so it slides off the handlebar. Bracket should pop off the handlebar and return to original shape.
    FixBotに聞いてみる
    コメントを追加
  3. Trek 4300 Bicycle Front Reflector Replacement, Replace Bracket: 手順 3、 1の画像 1
    • To replace the new reflector hold the bracket on the side of the handlebar opposite you with the flat pieces facing toward the front of the bike.
    • Spread the flat pieces apart and position the bracket so that the top flat piece will go over the top of the handlebar and the bottom piece will go underneath the handlebar.
    • Using light to moderate force, pull the bracket towards you so that it maneuvers around the bar. The bracket should now be reattached to the handlebar but spinning freely.
    FixBotに聞いてみる
    コメントを追加
  4. Trek 4300 Bicycle Front Reflector Replacement, Tighten Bracket: 手順 4、 1の画像 1
    • Holding the reflector so that it faces forwards, insert the screw so that it goes through the hole of both flat pieces of the bracket.
    • Using a Phillips-head screwdriver, tighten the bracket until it is snug around the handlebar.
    • Pull up and down lightly on the reflector to make sure it is securely in place.
    FixBotに聞いてみる
    コメントを追加
終わりに
It is important to remember that when replacing reflectors, any reflectors facing forward should be white/clear and any reflector facing backward should be red so cars and and other bikers know which direction you are heading.
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Emily OConnor
メンバー登録日: 10/13/14
500 ポイント
4のガイドは作成済み
チーム
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G2
4 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 48
今までの合計 2,237
