はじめに
With this guide you will be able to remove both left and right speakers and replace them.
必要な工具と部品
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
Remove the two 5mm screws using a Phillips #00 screwdriver.
Remove the left speaker.
もう少しです!
終わりに
