はじめに
If the processor fan stops working, and the system is overheating, Follow this guide to replace it.
必要な工具と部品
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
