メインコンテンツにスキップ
Toshiba Portege Z835-P330 Keyboard Replacement
必要な工具と部品
  1. Toshiba Portege Z835-P330 Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver
  2. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 2、 1の画像 1
    • Locate the hidden screw found in the middle of the back hard cover.
    • The hidden screw is found under the rubber cover shown in picture.
    • Here you will find a proprietary Japanese screw head.
    • Remove the screw with your own tool (not provided by IFixit) or by using the methods found here.
  3. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 3、 1の画像 1
    • Peel off the hardcover on the back of the device to expose the interior of the device.
    • Force may be required, but the hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 4、 1の画像 1
    • Remove the six screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the white Bundled Cable Connector by gently pulling it out of the socket. Follow the guide here.
    • Plug should easily detach with little force.
  6. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 6、 1の画像 1
    • Lift the battery up by its sides. The battery should easily come off.
  7. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 7、 1の画像 1
  8. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 8、 1の画像 1
    • Remove the two cables by following the direction here.
    • The cables should come off easily.
  9. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    購入する
    • Flip the device over to access the keyboard.
    • Insert the Opening Tool into the crevice on one side of keyboard frame.
    • Pry off the keyboard using the tool.
  10. Toshiba Portege Z835-P330 Keyboard Replacement: 手順 10、 1の画像 1
    • Pull off the rest of the keyboard with your hands when you're able to easily grab underneath the keyboard.
    • The keyboard will be taped underneath but will easily detach.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dominic Whiting
メンバー登録日: 02/08/18
915 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S2-G3, Thomas Spring 2018 University of North Texas, Team S2-G3, Thomas Spring 2018人のメンバー
UNT-THOMAS-S18S2G3
4 メンバー
15のガイドは作成済み
2 件のコメント
Ordering the parts for my wife’s Toshiba shortly. It has been an excellent machine but the keyboard keys have worn off. Seems like a very straight forward process. The question that I have is what do I use to hold the keyboard back in place?
Thanks for the directions. George
George Bootes - 返信
Only one key gets off the keyboard (down cursor) I’ve got the key and the rounded rubber that fits into the mechanism, most of the time it works but when I press continusly it gets off.
Is there a way to fix it without changing the whole keyboard?
Jesús Fernández Sánchez - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,603
