メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TomTom VIA 1605TM Battery Replacement
必要な工具と部品
    1. TomTom VIA 1605TM Battery Replacement, Front Screen: 手順 1、 3の画像 1 TomTom VIA 1605TM Battery Replacement, Front Screen: 手順 1、 3の画像 2 TomTom VIA 1605TM Battery Replacement, Front Screen: 手順 1、 3の画像 3
      • Locate the round suction cup on the back of the device.
      • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
      • When reassembling twist the suction cup but, push in as oppose to pulling out.
      FixBotに聞いてみる
      コメントを追加
    2. TomTom VIA 1605TM Battery Replacement: 手順 2、 1の画像 1
      • Location of screw is where the suction cup was.
      • Insert 8mm Hex #T6 screw driver into screw.
      • Unscrew in counter clockwise direction.
      • When reassembling screw in the clockwise direction.
      FixBotに聞いてみる
      コメントを追加
    3. TomTom VIA 1605TM Battery Replacement: 手順 3、 2の画像 1 TomTom VIA 1605TM Battery Replacement: 手順 3、 2の画像 2
      • Pry along the edges with the plastic opening tool to separate the back and front panel.
      • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
      FixBotに聞いてみる
      コメントを追加
    4. TomTom VIA 1605TM Battery Replacement: 手順 4、 3の画像 1 TomTom VIA 1605TM Battery Replacement: 手順 4、 3の画像 2 TomTom VIA 1605TM Battery Replacement: 手順 4、 3の画像 3
      • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
      • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
      FixBotに聞いてみる
      コメントを追加
    1. TomTom VIA 1605TM Battery Replacement, Battery: 手順 5、 3の画像 1 TomTom VIA 1605TM Battery Replacement, Battery: 手順 5、 3の画像 2 TomTom VIA 1605TM Battery Replacement, Battery: 手順 5、 3の画像 3
      • Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard.
      • Unscrew each of these in a counter clockwise direction.
      • When reassembling screw back in a clockwise direction.
      • The second picture is to represent where the four screws are located. The LCD screen does not disconnect from the motherboard until the next step
      FixBotに聞いてみる
      コメントを追加
    2. TomTom VIA 1605TM Battery Replacement: 手順 6、 3の画像 1 TomTom VIA 1605TM Battery Replacement: 手順 6、 3の画像 2 TomTom VIA 1605TM Battery Replacement: 手順 6、 3の画像 3
      • Remove the Blue Ribbon Cable by pushing each side of the plastic holder with the nylon spudger.
      • This will remove the LCD screen from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    3. TomTom VIA 1605TM Battery Replacement: 手順 7、 2の画像 1 TomTom VIA 1605TM Battery Replacement: 手順 7、 2の画像 2
      • Unplug the wire connecting to the battery by pinching the sides connected to the front screen.
      • Pull back away (in the opposite direction) from the connector.
      • Lift the circuit board to reveal the battery beneath.
      • When reassembling push back into connector. Do not need to pinch anything. The "click" sound insures solid connection.
      FixBotに聞いてみる
      コメントを追加
    4. TomTom VIA 1605TM Battery Replacement: 手順 8、 2の画像 1 TomTom VIA 1605TM Battery Replacement: 手順 8、 2の画像 2
      • Carefully pry loose using the plastic opening tool and remove the original battery.
      • Place the new battery where the old battery was located.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Mathew Fleurent
メンバー登録日: 10/19/15
125 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 4-4, Catania Fall 2015 UMass Dartmouth, Team 4-4, Catania Fall 2015人のメンバー
UMASSD-CATANIA-F15S4G4
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 29
今までの合計 1,435
