メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TomTom Runner GPS Component Replacement
必要な工具と部品
  1. TomTom Runner GPS Component Replacement, Wristband: 手順 1、 1の画像 1
    • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
    FixBotに聞いてみる
    コメントを追加
  2. TomTom Runner GPS Component Replacement: 手順 2、 2の画像 1 TomTom Runner GPS Component Replacement: 手順 2、 2の画像 2
    • Continue to lift up on the band until the screen of the watch becomes loose from the band.
    • You may need to apply a small amount of force downward on the face of the screen.
    • Continue to pull up on the wristband until it is completely off the watch.
    FixBotに聞いてみる
    コメントを追加
  3. TomTom Runner GPS Component Replacement, Back Panel: 手順 3、 1の画像 1
    • Grab the watch once it is separated from the wristband.
    FixBotに聞いてみる
    コメントを追加
  4. TomTom Runner GPS Component Replacement: 手順 4、 1の画像 1
    • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
    FixBotに聞いてみる
    コメントを追加
  5. TomTom Runner GPS Component Replacement: 手順 5、 2の画像 1 TomTom Runner GPS Component Replacement: 手順 5、 2の画像 2
    • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
    • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
    • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
    FixBotに聞いてみる
    コメントを追加
  6. TomTom Runner GPS Component Replacement: 手順 6、 2の画像 1 TomTom Runner GPS Component Replacement: 手順 6、 2の画像 2
    • Gently pull the back panel away from the front panel.
    • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
    FixBotに聞いてみる
    コメントを追加
  7. TomTom Runner GPS Component Replacement: 手順 7、 2の画像 1 TomTom Runner GPS Component Replacement: 手順 7、 2の画像 2
    • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
    • Be gentle with the red and black wires. You do not want them to rip or pop out.
    • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
    FixBotに聞いてみる
    コメントを追加
  8. TomTom Runner GPS Component Replacement, GPS Component: 手順 8、 2の画像 1 TomTom Runner GPS Component Replacement, GPS Component: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Now lift the smaller square of copper off the front panel. Use the precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
    • You will need to be gentle and pull the copper slowly so that it does not rip.
    FixBotに聞いてみる
    コメントを追加
  9. TomTom Runner GPS Component Replacement: 手順 9、 3の画像 1 TomTom Runner GPS Component Replacement: 手順 9、 3の画像 2 TomTom Runner GPS Component Replacement: 手順 9、 3の画像 3
    • Use your fingers to gently grab and lift the small square piece to remove the GPS and button component competely from the casing.
    • Disconnect the ZIF Connector from the larger green motherboard.
    • The ZIF Connector is the flat, orange cable connecting the small green motherboard to the larger motherboard. It is meant to come apart at the port located on the larger motherboard. You will feel like you have broken it when it is disconnected. That is okay!
    FixBotに聞いてみる
    コメントを追加
  10. TomTom Runner GPS Component Replacement: 手順 10、 3の画像 1 TomTom Runner GPS Component Replacement: 手順 10、 3の画像 2 TomTom Runner GPS Component Replacement: 手順 10、 3の画像 3
    • Get the GPS/Button Component by itself and use the Spudger tool to lift the silver cover off the GPS Component. This will expose the GPS Component.
    FixBotに聞いてみる
    コメントを追加
  11. TomTom Runner GPS Component Replacement: 手順 11、 2の画像 1 TomTom Runner GPS Component Replacement: 手順 11、 2の画像 2
    • Once the GPS Component cover is off and the GPS Component is exposed, you are ready to replace it.
    • The GPS Component is the entire square, grey box piece with the green motherboard attached to it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Amber Scarborough
メンバー登録日: 03/20/17
1,157 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G6
4 メンバー
15のガイドは作成済み
2件のガイドコメント
Where do i buy the GPS component for replacement?
tolstih.kirill - 返信 共有
Hi,
Thanx so much for this guide. Now I’m looking for a new GPS component.Do you know where I can buy that?
Regards, Rein Kooijman (the Netherlands)
Rein Kooijman - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 53
今までの合計 2,122
