メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TomTom Runner Front Cover Replacement
必要な工具と部品
  1. TomTom Runner Front Cover  Replacement, Wristband: 手順 1、 1の画像 1
    • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
    FixBotに聞いてみる
    コメントを追加
  2. TomTom Runner Front Cover  Replacement: 手順 2、 2の画像 1 TomTom Runner Front Cover  Replacement: 手順 2、 2の画像 2
    • Continue to lift up on the band until the screen of the watch becomes loose from the band.
    • You may need to apply a small amount of force downward on the face of the screen.
    • Continue to pull up on the wristband until it is completely off the watch.
    FixBotに聞いてみる
    コメントを追加
  3. TomTom Runner Front Cover  Replacement, Back Panel: 手順 3、 1の画像 1
    • Grab the watch once it is separated from the wristband.
    FixBotに聞いてみる
    コメントを追加
  4. TomTom Runner Front Cover  Replacement: 手順 4、 1の画像 1
    • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
    FixBotに聞いてみる
    コメントを追加
  5. TomTom Runner Front Cover  Replacement: 手順 5、 2の画像 1 TomTom Runner Front Cover  Replacement: 手順 5、 2の画像 2
    • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
    • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
    • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
    FixBotに聞いてみる
    コメントを追加
  6. TomTom Runner Front Cover  Replacement: 手順 6、 2の画像 1 TomTom Runner Front Cover  Replacement: 手順 6、 2の画像 2
    • Gently pull the back panel away from the front panel.
    • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
    FixBotに聞いてみる
    コメントを追加
  7. TomTom Runner Front Cover  Replacement: 手順 7、 2の画像 1 TomTom Runner Front Cover  Replacement: 手順 7、 2の画像 2
    • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
    • Be gentle with the red and black wires. You do not want them to rip or pop out.
    • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
    FixBotに聞いてみる
    コメントを追加
  8. TomTom Runner Front Cover  Replacement, Front Cover: 手順 8、 2の画像 1 TomTom Runner Front Cover  Replacement, Front Cover: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
    • You will need to be gentle and pull the copper slowly so that it does not rip.
    FixBotに聞いてみる
    コメントを追加
  9. TomTom Runner Front Cover  Replacement: 手順 9、 2の画像 1 TomTom Runner Front Cover  Replacement: 手順 9、 2の画像 2
    • Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
    FixBotに聞いてみる
    コメントを追加
  10. TomTom Runner Front Cover  Replacement: 手順 10、 1の画像 1
    • Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
    FixBotに聞いてみる
    コメントを追加
  11. TomTom Runner Front Cover  Replacement: 手順 11、 3の画像 1 TomTom Runner Front Cover  Replacement: 手順 11、 3の画像 2 TomTom Runner Front Cover  Replacement: 手順 11、 3の画像 3
    • Use your fingers to gently pull the whole green motherboard out of the Front Casing.
    • If you have trouble using your fingers, then use the black Spudger tool.
    FixBotに聞いてみる
    コメントを追加
終わりに
You are finished when all parts have been removed to leave just the front casing by itself. To reassemble your device, follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Amber Scarborough
メンバー登録日: 03/20/17
1,157 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G6
4 メンバー
15のガイドは作成済み
9件のガイドコメント
Great explaination, though you mention you don't replacement parts...? Can you share a link where you found the new front cover assembly?
steffen klifman - 返信 共有
Same question as Dyeffen : where can we get some replacement screens ?
Ansre
a_limal@yahoo.com.au
Andre - 返信 共有
Steffen sorry :-(
Andre - 返信 共有
Same question: where can we find the replacement cover part?
Thomas - 返信 共有
Hello if the control button is tight can the button be removed and cleaned underneath
Imran
Imran Moosagie - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 32
今までの合計 6,851
