メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TomTom Runner Battery Replacement Guide
必要な工具と部品
    1. TomTom Runner Battery  Replacement Guide, Wristband: 手順 1、 1の画像 1
      • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
      FixBotに聞いてみる
      コメントを追加
    2. TomTom Runner Battery  Replacement Guide: 手順 2、 2の画像 1 TomTom Runner Battery  Replacement Guide: 手順 2、 2の画像 2
      • Continue to lift up on the band until the screen of the watch becomes loose from the band.
      • You may need to apply a small amount of force downward on the face of the screen.
      • Continue to pull up on the wristband until it is completely off the watch.
      FixBotに聞いてみる
      コメントを追加
    1. TomTom Runner Battery  Replacement Guide, Back Panel: 手順 3、 1の画像 1
      • Grab the watch once it is separated from the wristband.
      FixBotに聞いてみる
      コメントを追加
    2. TomTom Runner Battery  Replacement Guide: 手順 4、 1の画像 1
      • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. TomTom Runner Battery  Replacement Guide: 手順 5、 2の画像 1 TomTom Runner Battery  Replacement Guide: 手順 5、 2の画像 2
      • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
      • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
      • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
      FixBotに聞いてみる
      コメントを追加
    4. TomTom Runner Battery  Replacement Guide: 手順 6、 2の画像 1 TomTom Runner Battery  Replacement Guide: 手順 6、 2の画像 2
      • Gently pull the back panel away from the front panel.
      • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
      FixBotに聞いてみる
      コメントを追加
    5. TomTom Runner Battery  Replacement Guide: 手順 7、 2の画像 1 TomTom Runner Battery  Replacement Guide: 手順 7、 2の画像 2
      • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
      • Be gentle with the red and black wires. You do not want them to rip or pop out.
      • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
      FixBotに聞いてみる
      コメントを追加
    1. TomTom Runner Battery  Replacement Guide, Battery: 手順 8、 3の画像 1 TomTom Runner Battery  Replacement Guide, Battery: 手順 8、 3の画像 2 TomTom Runner Battery  Replacement Guide, Battery: 手順 8、 3の画像 3
      • Grab the back panel and a blue, plastic opening tool to pry the black battery pack off the back panel.
      • The battery pack is glued down, so it will be a bit sticky and harder to get off.
      • After removing the battery, you are ready to replace it with a new one.
      • If you need to replace the back panel, you are ready to take out the old battery and place it in the new back panel.
      FixBotに聞いてみる
      コメントを追加
終わりに
This guide is complete when you have successfully removed the battery from the back panel. To reassemble your device, follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
20 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Amber Scarborough
メンバー登録日: 03/20/17
1,157 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S8G6
4 メンバー
15のガイドは作成済み
30件のガイドコメント
Ready to replace the battery. Would you happen to know where one can get a replacement battery?
Thanks
D.
Dan G - 返信 共有
where can you get a replacement battery for a tomtom watch 8rgo
john cash - 返信 共有
8gro battery where do I find one
Barend Fensham - 返信 共有
Very nice explaination. Would be good to mention the replacementbattery.
Very hard to find on the www.
Anyone found out already?
Know it’s lithium polymer with capacity of 190 mAh / 3,7V
When size is known, a replacement must be somewere.
Daan Ouwehand - 返信 共有
Can someone advise where we can purchase these batteries
sheldon Reddy - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 93
今までの合計 86,759
