メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Claw "Claw" Replacement
必要な工具と部品
    1. The Claw  "Claw" Replacement, Top Cover: 手順 1、 1の画像 1
      • Place The Claw machine in the up-right position with the control knobs facing you.
      FixBotに聞いてみる
      コメントを追加
    2. The Claw  "Claw" Replacement: 手順 2、 1の画像 1
      • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
      FixBotに聞いてみる
      コメントを追加
    3. The Claw  "Claw" Replacement: 手順 3、 1の画像 1
      • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
      • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
      FixBotに聞いてみる
      コメントを追加
    4. The Claw  "Claw" Replacement: 手順 4、 1の画像 1
      • Turn The Claw machine back to the upright position with controls facing you.
      FixBotに聞いてみる
      コメントを追加
    5. The Claw  "Claw" Replacement: 手順 5、 1の画像 1
      • Remove the top cover of The Claw machine.
      FixBotに聞いてみる
      コメントを追加
    6. The Claw  "Claw" Replacement: 手順 6、 2の画像 1 The Claw  "Claw" Replacement: 手順 6、 2の画像 2
      • Remove the ten 6 mm phillips #1 screws from the top flange.
      FixBotに聞いてみる
      コメントを追加
    7. The Claw  "Claw" Replacement: 手順 7、 1の画像 1
      • Lift the flange upward and off to the side of the machine.
      • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
      • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
      FixBotに聞いてみる
      コメントを追加
    1. The Claw  "Claw" Replacement, Claw: 手順 8、 1の画像 1
      • Once you have removed the top cover of the claw you can easily access the claw and you will see that the claw is attached by two small chains.
      • Locate the small rings that attach the chain to the plastic claw.
      FixBotに聞いてみる
      コメントを追加
    2. The Claw  "Claw" Replacement: 手順 9、 1の画像 1
      この手順で使用する道具:
      • Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
      • Replace the claw one ring at a time. The chain needs to be attached to the new claw in the same configuration. One side of the chain opens the claw and the other side is just a hanging support.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alain Pierre
メンバー登録日: 03/22/16
1,188 ポイント
9のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G8
3 メンバー
18のガイドは作成済み
7件のガイドコメント
Where do I buy a new grabber thing
Oliver Chew - 返信 共有
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - 返信 共有
What if the chain won't go down as it deep as it used to be?
Mira DIP - 返信 共有
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - 返信 共有
My chain fell off and I dont know how to fix
Kathellyn Da silva - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 140
今までの合計 12,055
