メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Texas Instruments TI-80 Button Replacement
必要な工具と部品
    1. Texas Instruments TI-80 Button Replacement, Batteries: 手順 1、 1の画像 1
      • Locate battery cover on the back of the case.
      • Slide battery cover to the right reveal the batteries.
      FixBotに聞いてみる
      コメントを追加
    2. Texas Instruments TI-80 Button Replacement: 手順 2、 1の画像 1
      • Remove battery cover.
      • Slide the red lock down.
      • Slide the metal tab to the right of the top battery.
      • Remove the 3-Volt Lithium Coin Cell Battery.
      • Slide the red lock up.
      • Slide the metal tab to the right of the bottom battery.
      FixBotに聞いてみる
      コメントを追加
    1. Texas Instruments TI-80 Button Replacement, Back Case: 手順 3、 3の画像 1 Texas Instruments TI-80 Button Replacement, Back Case: 手順 3、 3の画像 2 Texas Instruments TI-80 Button Replacement, Back Case: 手順 3、 3の画像 3
      • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
      • Unscrew four 7.15 mm screws from back casing.
      • Using the blue plastic opener tool along the seam of the case, pry off front casing.
      • Start prying from the bottom of the calculator as the casing hooks into the top.
      FixBotに聞いてみる
      コメントを追加
    1. Texas Instruments TI-80 Button Replacement, Motherboard and Screen: 手順 4、 2の画像 1 Texas Instruments TI-80 Button Replacement, Motherboard and Screen: 手順 4、 2の画像 2
      • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
      • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
      • Using the blue plastic opening tool, pry the Motherboard up.
      • Using the blue plastic opening tool, pry up the screen from the screen mount.
      FixBotに聞いてみる
      コメントを追加
    1. Texas Instruments TI-80 Button Replacement, Check keyboard mat: 手順 5、 2の画像 1 Texas Instruments TI-80 Button Replacement, Check keyboard mat: 手順 5、 2の画像 2
      • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
      • Flip the mat over to assess dirt and damage.
      • Replace the mat if it is damaged.
      • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
      FixBotに聞いてみる
      コメントを追加
    1. Texas Instruments TI-80 Button Replacement, Check Buttons: 手順 6、 1の画像 1
      • Check the back of the buttons for damage or obstructions.
      • If obstructions are present, clear them.
      • Do not tilt the calculator, or buttons may fall out.
      FixBotに聞いてみる
      コメントを追加
    2. Texas Instruments TI-80 Button Replacement, Replace Buttons: 手順 7、 1の画像 1
      この手順で使用する道具:
      • If a button is damaged, use tweezers to lift the button out of the facing.
      FixBotに聞いてみる
      コメントを追加
    3. Texas Instruments TI-80 Button Replacement, Insert new Buttons: 手順 8、 1の画像 1
      • Insert new button, making sure that it is positioned properly.
      • For all buttons, there is an extrusion in the upper left quadrant when looking at the back of the key. These should be aligned with the top of the calculator.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
9人の作成者と共同で作成されました。
Calvin
メンバー登録日: 01/08/15
201 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Carnegie Winter 2015 Eastern Washington University, Team 1-1, Carnegie Winter 2015人のメンバー
EWU-CARNEGIE-W15S1G1
4 メンバー
35のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 830
