メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Tagital T10 Power button Replacement
必要な工具と部品
  1. Tagital T10 Power button Replacement, Power button: 手順 1、 1の画像 1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4 mm Phillips head screws at the top of the tablet.
    FixBotに聞いてみる
    コメントを追加
  2. Tagital T10 Power button Replacement: 手順 2、 1の画像 1
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Carefully set the back cover aside so that you do not rip the wires free.
    FixBotに聞いてみる
    コメントを追加
  3. Tagital T10 Power button Replacement: 手順 3、 1の画像 1
    • Remove all of the 4mm screws that attach the display screen to the back of the touch screen with brackets.
    • There should be a total of 8 screws and at size PH000.
    FixBotに聞いてみる
    コメントを追加
  4. Tagital T10 Power button Replacement: 手順 4、 2の画像 1 Tagital T10 Power button Replacement: 手順 4、 2の画像 2
    • Remove all of the 4mm screws that attach the motherboard to the rest of the device.
    • One screw is located beneath the black tape that holds the rear-facing camera in place. Peel the tape up to access it.
    • There should be a total of 7 screws at size PH000.
    FixBotに聞いてみる
    コメントを追加
  5. Tagital T10 Power button Replacement: 手順 5、 2の画像 1 Tagital T10 Power button Replacement: 手順 5、 2の画像 2
    • Locate the 2 ZIF connectors.
    • Flip up the black tab to release the two filaments, so that they are no longer connected to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Tagital T10 Power button Replacement: 手順 6、 2の画像 1 Tagital T10 Power button Replacement: 手順 6、 2の画像 2
    • Locate the notification light on the upper corner of the device.
    • Gently pull on the wires to remove the light from it's housing.
    FixBotに聞いてみる
    コメントを追加
  7. Tagital T10 Power button Replacement: 手順 7、 1の画像 1
    • Remove the motherboard from the back of the display screen.
    • Some wires are still attached to the device, so carefully set it to the side.
    FixBotに聞いてみる
    コメントを追加
  8. Tagital T10 Power button Replacement: 手順 8、 2の画像 1 Tagital T10 Power button Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Push the power button towards the interior of the device to free it from its slot, using tweezers.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Destin Dawsy
メンバー登録日: 09/26/16
328 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 14-5, Eyestone Fall 2016 USF Tampa, Team 14-5, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 38
今までの合計 669
