メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Tabby Kidz Screen Replacement
必要な工具と部品
    1. Tabby Kidz Screen Replacement, Dismantling the tablet.: 手順 1、 3の画像 1 Tabby Kidz Screen Replacement, Dismantling the tablet.: 手順 1、 3の画像 2 Tabby Kidz Screen Replacement, Dismantling the tablet.: 手順 1、 3の画像 3
      • Gently insert a metal wedge into the crease on the side of the tablet.
      • Use a plastic prying tool to crack the side of the tablet open.
      • Be careful when you do this. You should not use excessive force as there are wires connecting the speaker in the back of the tablet and the front side of the tablet.
      • Once you have opened the tablet, use a plastic prying tool in order to remove the speaker in the backside of the tablet. This will enable you to properly separate both sides of the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. Tabby Kidz Screen Replacement, Securing the ribbon wire.: 手順 2、 1の画像 1
      • There are ribbon wires on the sides of tablet. You will need to unhook the ribbon wires attached to the screen in order to secure them from tearing. The ribbon wires connect the mother board and the screen.
      • The ribbon wires are very delicate. Use extreme caution or else they might tear.
      FixBotに聞いてみる
      コメントを追加
    3. Tabby Kidz Screen Replacement, Removing the screws attaching the motherboard to the tablet.: 手順 3、 1の画像 1
      • There are 3 Ph 00 screws (4 mm long) that connect the motherboard to the tablet. These screws are indicated in the image by special markers. Once you have located these screws, unscrew them.
      FixBotに聞いてみる
      コメントを追加
    4. Tabby Kidz Screen Replacement, Removing the inner screen: 手順 4、 3の画像 1 Tabby Kidz Screen Replacement, Removing the inner screen: 手順 4、 3の画像 2 Tabby Kidz Screen Replacement, Removing the inner screen: 手順 4、 3の画像 3
      • In order to remove the inner screen, you must first unscrew the screws connecting the screen to the tablet using a ph 00 screw driver. The screws are 3mm in length.
      • Next, using a prying tool, gently remove the inner screen.
      • DO NOT try to separate the inner screen from the motherboard in this step.
      FixBotに聞いてみる
      コメントを追加
    5. Tabby Kidz Screen Replacement, Replacing the broken screen.: 手順 5、 1の画像 1
      • Install new screen for your tablet.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Mohamed
メンバー登録日: 01/26/15
65 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 789
