メインコンテンツにスキップ
TOZO HT2 Daughterboard Replacement
必要な工具と部品
  1. TOZO HT2 Daughterboard Replacement, Ear Pad: 手順 1、 3の画像 1 TOZO HT2 Daughterboard Replacement, Ear Pad: 手順 1、 3の画像 2 TOZO HT2 Daughterboard Replacement, Ear Pad: 手順 1、 3の画像 3
    • Firmly hold the headphone housing in one hand to hold the device steady and put the other hand on the ear pad you intend to replace.
    • Note: Do not force the ear pad to come off or you risk breaking the tabs that keep the pads in place.
  2. TOZO HT2 Daughterboard Replacement: 手順 2、 3の画像 1 TOZO HT2 Daughterboard Replacement: 手順 2、 3の画像 2 TOZO HT2 Daughterboard Replacement: 手順 2、 3の画像 3
    • Twist the ear cover counterclockwise until it pops off.
    • Repeat for the other ear pad if necessary.
  3. TOZO HT2 Daughterboard Replacement, Daughterboard: 手順 3、 1の画像 1
    • Use a Phillips screwdriver to remove all four screws that secure the right speaker cover.
    • Lift the cover off without pulling on the wires inside and set it to the side to access the circuit board.
  4. TOZO HT2 Daughterboard Replacement: 手順 4、 3の画像 1 TOZO HT2 Daughterboard Replacement: 手順 4、 3の画像 2 TOZO HT2 Daughterboard Replacement: 手順 4、 3の画像 3
    • Unscrew the circuit board and gently pull it up from the plastic tab it sits on.
  5. TOZO HT2 Daughterboard Replacement: 手順 5、 1の画像 1
    • Carefully use flush cutters, to cut the wires connecting to the circuit board and the battery.
    • Be careful not to cut the wires too short. Ideally, as close to the circuit board and battery as possible removing minimal wire.
  6. TOZO HT2 Daughterboard Replacement: 手順 6、 1の画像 1
    • Use this guide to reattach the wires to the circuit board.
    • HANDLE WITH CARE: Soldering Iron becomes VERY Hot (Up to or above 400°C or 800°F).
    • Wear eye protection while soldering and only do so in a well ventilated room and/or with a fume extractor.
    • Remove all possible fire hazards from the surrounding area.
    • Keep all animals and children out of the room.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
4人の作成者と共同で作成されました。
Raven M
メンバー登録日: 08/28/24
605 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team 7-2, Kilpatrick Fall 2024 University of North Texas, Team 7-2, Kilpatrick Fall 2024人のメンバー
UNT-KILPATRICK-F24S7G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 79
