メインコンテンツにスキップ
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
必要な工具と部品
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 手順 1、 3の画像 1 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 手順 1、 3の画像 2 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: 手順 1、 3の画像 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 手順 2、 1の画像 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 手順 3、 1の画像 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 手順 4、 3の画像 1 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 手順 4、 3の画像 2 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: 手順 4、 3の画像 3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 手順 5、 1の画像 1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: 手順 6、 1の画像 1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Logan Sluder
メンバー登録日: 09/18/19
544 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team S1-G4, Virtue Fall 2019 Western Carolina University, Team S1-G4, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G4
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 597
