メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Swagtron T3 Gyroscope Replacement
必要な工具と部品
    1. Swagtron T3 Gyroscope Replacement, Cover: 手順 1、 2の画像 1 Swagtron T3 Gyroscope Replacement, Cover: 手順 1、 2の画像 2
      • Make sure the hoverboard is completely powered off and unplugged from any outlets.
      • Flip the Swagtron so that the footpads are facing the ground.
      • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
      FixBotに聞いてみる
      コメントを追加
    2. Swagtron T3 Gyroscope Replacement: 手順 2、 3の画像 1 Swagtron T3 Gyroscope Replacement: 手順 2、 3の画像 2 Swagtron T3 Gyroscope Replacement: 手順 2、 3の画像 3
      • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
      • Slowly lift the backside cover.
      • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
      • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
      • Three cables on the motherboard side.
      • Two red cables with white connectors and one white cable with a white connector.
      • One yellow cable with a black connector on the battery side.
      • After detachment, you should be able to completely remove the backside cover.
      FixBotに聞いてみる
      コメントを追加
    1. Swagtron T3 Gyroscope Replacement, Gyroscope: 手順 3、 1の画像 1
      • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
      • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
      • Three red and black cables with white connectors.
      • One multicolored cable with a black connector.
      FixBotに聞いてみる
      コメントを追加
    2. Swagtron T3 Gyroscope Replacement: 手順 4、 1の画像 1
      • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
      FixBotに聞いてみる
      コメントを追加
    3. Swagtron T3 Gyroscope Replacement: 手順 5、 2の画像 1 Swagtron T3 Gyroscope Replacement: 手順 5、 2の画像 2
      • Cut the plastic cable tie holding the cables together with utility scissors.
      • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
      FixBotに聞いてみる
      コメントを追加
    4. Swagtron T3 Gyroscope Replacement: 手順 6、 1の画像 1
      • Gently lift the blue gyroscope off of the white plastic holder piece.
      • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
      • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Emily Richter
メンバー登録日: 04/10/17
351 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G3
4 メンバー
12のガイドは作成済み
3件のガイドコメント
Where can one buy the new gyroscope?
Mike - 返信 共有
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
Mike - 返信 共有
where can I buy new gyroscope
roccovalletta - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 40
今までの合計 5,552
