メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SwagTron T1 Wheel Replacement
必要な工具と部品
    1. SwagTron T1 Wheel Replacement, Back Panels: 手順 1、 1の画像 1
      • Ensure that the SwagTron is off.
      • Turn the SwagTron upside down to see the underside.
      FixBotに聞いてみる
      コメントを追加
    2. SwagTron T1 Wheel Replacement: 手順 2、 3の画像 1 SwagTron T1 Wheel Replacement: 手順 2、 3の画像 2 SwagTron T1 Wheel Replacement: 手順 2、 3の画像 3
      • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
      • The screws are tightly in place. It will take effort to screw them out.
      • The panel is still attached to the SwagTron by wires that go to the motherboard.
      • Carefully lift the panels off
      FixBotに聞いてみる
      コメントを追加
    3. SwagTron T1 Wheel Replacement: 手順 3、 3の画像 1 SwagTron T1 Wheel Replacement: 手順 3、 3の画像 2 SwagTron T1 Wheel Replacement: 手順 3、 3の画像 3
      • Follow the wires from the panels to the motherboard.
      • You may need to cut any zip ties that are holding the wires together.
      • There is one connection on the battery side and three on the other side that must be removed.
      • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
      • Your back panels are now completely removed.
      FixBotに聞いてみる
      コメントを追加
    1. SwagTron T1 Wheel Replacement, Wheel: 手順 4、 3の画像 1 SwagTron T1 Wheel Replacement, Wheel: 手順 4、 3の画像 2 SwagTron T1 Wheel Replacement, Wheel: 手順 4、 3の画像 3
      • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
      • Carefully remove this component and set it off to the side.
      FixBotに聞いてみる
      コメントを追加
    2. SwagTron T1 Wheel Replacement: 手順 5、 3の画像 1 SwagTron T1 Wheel Replacement: 手順 5、 3の画像 2 SwagTron T1 Wheel Replacement: 手順 5、 3の画像 3
      • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
      • Take off the iron plate holding the wheel in place.
      • Remove the Motor/Wheel and set it aside close by to the hoverboard.
      • The wires from the Motor/Wheel should still be connected to the motherboard.
      • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
      FixBotに聞いてみる
      コメントを追加
    3. SwagTron T1 Wheel Replacement: 手順 6、 3の画像 1 SwagTron T1 Wheel Replacement: 手順 6、 3の画像 2 SwagTron T1 Wheel Replacement: 手順 6、 3の画像 3
      この手順で使用する道具:
      • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
      • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
      • Separate the set of marked green, blue, and yellow wires from their connectors.
      FixBotに聞いてみる
      コメントを追加
    4. SwagTron T1 Wheel Replacement: 手順 7、 3の画像 1 SwagTron T1 Wheel Replacement: 手順 7、 3の画像 2 SwagTron T1 Wheel Replacement: 手順 7、 3の画像 3
      • Finally separate the last connector shown on the left.
      • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
      • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Teagan Allen
メンバー登録日: 04/18/17
432 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S17G5
4 メンバー
15のガイドは作成済み
3件のガイドコメント
Where do you get replacement wheels?
Elizabeth Schumacher - 返信 共有
Where can we find replacement wheels?
Liz Vance - 返信 共有
Mine won't stop beeping?? Fully charged.
Rachael Anderson - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 49
今までの合計 6,620
