メインコンテンツにスキップ
Stuck Luggage Handle Lubrication
必要な工具と部品
  1. Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 手順 1、 3の画像 1 Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 手順 1、 3の画像 2 Stuck Luggage Handle Lubrication, Gain Access into Liner Compartment: 手順 1、 3の画像 3
    • Open the zipper at the base of the bag, then open the zipper in the compartment liner to expose the handle mechanisms.
    • Inspect the handle housing.
    • All metal bars should be straight and plastic housings should be intact. This guide cannot fix handles that are stuck due to any damage to the hardware.
  2. Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 手順 2、 3の画像 1 Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 手順 2、 3の画像 2 Stuck Luggage Handle Lubrication, Check Function of Toggle Buttons: 手順 2、 3の画像 3
    • There are multiple sets of holes along the external sides of the handle housing. The toggle buttons of the handle (sometimes referred to as 'spring clips') lock into these holes, raising and lowering the height of the retractable handle.
    • Check the function of this mechanism by pressing the handle's release button and watching the toggle buttons:
    • When the luggage handle is fully functional, the handle release button causes these toggle buttons to fully retract into the holes.
    • When the luggage handle mechanism is sticky or fully stuck, the handle release button does not cause the toggle buttons to retract properly.
  3. Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 手順 3、 3の画像 1 Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 手順 3、 3の画像 2 Stuck Luggage Handle Lubrication, Depress Toggle Buttons to Test Handle: 手順 3、 3の画像 3
    • With one hand pressing the handle release button, use a pointed object (like a screwdriver) in the other hand to depress each toggle button into the handle housing manually. This should allow the handle to slide to a new position.
  4. Stuck Luggage Handle Lubrication, Remove Handle Clips: 手順 4、 3の画像 1 Stuck Luggage Handle Lubrication, Remove Handle Clips: 手順 4、 3の画像 2 Stuck Luggage Handle Lubrication, Remove Handle Clips: 手順 4、 3の画像 3
    • Use a Phillips PH1 screwdriver to remove the four screws at the top handle bracket.
    • Then remove the two black plastic retaining clips that were kept in place by the red screws.
    • Be careful not to lose these pieces! Put them somewhere safe and accessible, they'll be reused later on.
  5. Stuck Luggage Handle Lubrication, Remove Handle: 手順 5、 3の画像 1 Stuck Luggage Handle Lubrication, Remove Handle: 手順 5、 3の画像 2 Stuck Luggage Handle Lubrication, Remove Handle: 手順 5、 3の画像 3
    • Using the screwdriver trick from Step 3, depress the toggle buttons and pull the handle out of the handle housing as far as you can.
    • Once the handle is in its highest position, use a repeated side-to-side movement to free the black plastic sleeves on the bottom portion of the handle.
    • With the handle separated from the bag, press the handle release button multiple times and take a mental note of how deep the toggle buttons depress.
  6. Stuck Luggage Handle Lubrication, Lubricate Handle: 手順 6、 3の画像 1 Stuck Luggage Handle Lubrication, Lubricate Handle: 手順 6、 3の画像 2 Stuck Luggage Handle Lubrication, Lubricate Handle: 手順 6、 3の画像 3
    • Spray lubricant into the toggle button mechanism on both sides of the handle. Wipe away excess lubricant with a rag.
    • We recommend using Gear Hugger Multipurpose Lubricant. Functional substitutes include 3-IN-ONE Oil and WD-40.
    • Press the handle release button repeatedly to spread the lubricant within the mechanism.
    • The toggle buttons should depress noticeably deeper than in Step 5. Reapply lubricant and retest if necessary.
    • Apply a thin layer of lubricant to the bars of the removed handle. Wipe away any excess.
  7. Stuck Luggage Handle Lubrication, Reinsert Handle into Bag: 手順 7、 2の画像 1 Stuck Luggage Handle Lubrication, Reinsert Handle into Bag: 手順 7、 2の画像 2
    • Reinsert the handle:
    • While holding the handle release button, use a repeated up-and-down movement to insert the black plastic sleeves into the handle housing.
    • Continue to hold the handle release button, and insert the handle all the way back in.
    • You should notice the handle's function has dramatically increased.
    • Move the handle up and down, testing every position.
    • If the handle is still malfunctioning, it may need to be fully replaced.
  8. Stuck Luggage Handle Lubrication, Reinstall Plastic Clips: 手順 8、 2の画像 1 Stuck Luggage Handle Lubrication, Reinstall Plastic Clips: 手順 8、 2の画像 2
    • Reinstall the 2 black plastic clips.
    • Reinstall all 4 red screws.
    • Do not overtighten.
  9. Stuck Luggage Handle Lubrication, Close Bag: 手順 9、 2の画像 1 Stuck Luggage Handle Lubrication, Close Bag: 手順 9、 2の画像 2
    • Check the liner compartment to make sure no tools have been left behind.
    • Close the zipper at the perimeter of the liner.
    • Close the zipper to the compartment at the bottom of the bag.
ゴール
作成者
3人の作成者と共同で作成されました。
Zach Mueller
メンバー登録日: 02/23/23
1,490 ポイント
8のガイドは作成済み
チーム
Patagonia Patagonia人のメンバー
Community
17 メンバー
121のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 41
過去 30 日: 131
今までの合計 664
