メインコンテンツにスキップ
SteelSeries Nimbus+ Triggers Replacement
必要な工具と部品
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 手順 1、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 手順 1、 2の画像 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: 手順 2、 1の画像 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: 手順 3、 1の画像 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 手順 4、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 手順 4、 2の画像 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 手順 5、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 手順 5、 2の画像 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 手順 6、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 手順 6、 2の画像 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 手順 7、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 手順 7、 2の画像 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 手順 8、 3の画像 1 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 手順 8、 3の画像 2 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 手順 8、 3の画像 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 手順 9、 3の画像 1 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 手順 9、 3の画像 2 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: 手順 10、 1の画像 1
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: 手順 11、 1の画像 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 1 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 2 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 手順 12、 3の画像 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: 手順 13、 1の画像 1
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: 手順 14、 1の画像 1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 手順 15、 3の画像 1 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 手順 15、 3の画像 2 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 手順 15、 3の画像 3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: 手順 16、 1の画像 1
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 手順 17、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 手順 17、 2の画像 2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 手順 18、 2の画像 1 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 手順 18、 2の画像 2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
終わりに
Adriana Zwink
メンバー登録日: 12/18/19
62,043 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,638のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 12
今までの合計 426
