メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSteam Controllerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Steam Controller Disassembly, Beginning: 手順 1、 2の画像 1 Steam Controller Disassembly, Beginning: 手順 1、 2の画像 2
    • I did not have a long enough screwdriver, so I ended up drilling out two of the four side screws.
    • Go ahead and take off the back plate and remove the batteries.
    FixBotに聞いてみる
    コメントを追加
  2. Steam Controller Disassembly, Remove 4 side external screws: 手順 2、 3の画像 1 Steam Controller Disassembly, Remove 4 side external screws: 手順 2、 3の画像 2 Steam Controller Disassembly, Remove 4 side external screws: 手順 2、 3の画像 3
    • Start by taking out the 4 obvious screws, two on each side.
    • You'll need a long-necked T6 driver if you want to get these out cleanly. (At least 1" / 25mm.)
    • The pro tech toolkit does not have one long enough, so I used a slightly hacked hex key on two of them (stripping the heads) and ended up drilling out the other two because the hex key is not a good fit.
    FixBotに聞いてみる
    コメントを追加
  3. Steam Controller Disassembly, Remove 3 center inner screws: 手順 3、 1の画像 1
    • These are hidden under the label, simply use a sharp blade or just punch through the label with something sharp.
    • There are two at the top just outside the holes showing metal, and one near the bottom center.
    • The two at the top are much deeper in, but my normal T6 fits just fine.
    FixBotに聞いてみる
    コメントを追加
  4. Steam Controller Disassembly, Carefully pry off backplate: 手順 4、 2の画像 1 Steam Controller Disassembly, Carefully pry off backplate: 手順 4、 2の画像 2
    • Starting at the bottom center seems easiest and leaves the least amount of visual scratches.
    • Go all the way around, going below/behind the USB port. (see second picture)
    FixBotに聞いてみる
    コメントを追加
  5. Steam Controller Disassembly, Watch for loose plastic parts: 手順 5、 3の画像 1 Steam Controller Disassembly, Watch for loose plastic parts: 手順 5、 3の画像 2 Steam Controller Disassembly, Watch for loose plastic parts: 手順 5、 3の画像 3
    • Upon removing the backplate, there will be two battery hinges that may come off on either side.
    • I recommend keeping them on the backplate for reassembly later.
    • Next there is the backplate release switch, composed of two plastic parts and two springs.
    • See the 3rd picture of those parts.
    FixBotに聞いてみる
    コメントを追加
  6. Steam Controller Disassembly, Four Motherboard screws: 手順 6、 1の画像 1
    • Two screws near the top center.
    • Two screws on the far sides on top of the battery holder plastic backings.
    • Don't take the motherboard off yet - there are ribbon cables attached underneath.
    FixBotに聞いてみる
    コメントを追加
  7. Steam Controller Disassembly, Four touchpad bracket screws: 手順 7、 1の画像 1
    • Two screws hold each touchpad in place. They are mirrored across.
    • You might need to lift the motherboard by a finger's width to reach two of the four screws. (They are slightly underneath the battery holder plastic.)
    FixBotに聞いてみる
    コメントを追加
  8. Steam Controller Disassembly, Take the motherboard out: 手順 8、 1の画像 1
    • The only thing attached to the trackpads are the ribbon cables, be careful when lifting the motherboard off the front face plastic.
    • Watch out for the buttons falling out if you flip the front face over. There is a rubber/conductive silicone part that covers them all.
    FixBotに聞いてみる
    コメントを追加
  9. Steam Controller Disassembly, Optional: detaching ribbon cables: 手順 9、 2の画像 1 Steam Controller Disassembly, Optional: detaching ribbon cables: 手順 9、 2の画像 2
    この手順で使用する道具:
    • This step is only needed if you are replacing a trackpad.
    • These ribbon cables are actually really easy to take out, just tug gently straight away from the board.
    • ESD-safe tweezers are recommended for re-insertion, as the stiff ends are very small and difficult to grasp.
    FixBotに聞いてみる
    コメントを追加
  10. Steam Controller Disassembly, Optional: Front USB I/O panel, top bumper buttons: 手順 10、 2の画像 1 Steam Controller Disassembly, Optional: Front USB I/O panel, top bumper buttons: 手順 10、 2の画像 2
    • This thing literally just pops off using two plastic pressure-based latches. Just pull it in the direction the USB cable would go from the motherboard.
    • When the USB I/O panel comes off, so will the two bumper buttons. The two top bumpers are actually one long plastic part, who knew?
    FixBotに聞いてみる
    コメントを追加
  11. Steam Controller Disassembly, Optional: Bumper Triggers / Buttons: 手順 11、 1の画像 1
    • The screw for the bumper setups is on the opposite side of the motherboard, under the trackpad location.
    FixBotに聞いてみる
    コメントを追加
作成者
5人の作成者と共同で作成されました。
Ben Klein
メンバー登録日: 08/06/18
238 ポイント
1ガイドが承認済み
5件のガイドコメント
Thanks for the pictures, one of the two springs at part 5 jumped out, And I could for the life of me not figure out where it belonged.
lornlynx - 返信 共有
Much appreciated! I'm about to pop mine over to give them a good clean!
Steph Meslin-Weber - 返信 共有
Thank you, i finally got around to ordering some long torx to be able to disassemble this. Added some tape to the top bumpers to make them less stiff, and swapped the stick to a convex one. I hate screws under stickers lol.
MrRooter forthewin - 返信 共有
@christianl49355 A year late, but one of the springs goes to the side of the battery cover release switch, on a small plastic peg, and the other goes inside the small square hole that the D-shaped component of the release switch pushes into. You can just see the one inside the square hole in the photo above.
Oz Browning - 返信 共有
I have a T6 torx (it's the same one that I've used to undo hard drive screws), and I can't for the life of me actually get it to bind to any of the screws in the Steam Controller to actually unscrew them. Is there a trick I'm missing? I'm afraid just blindly pushing and spinning is just going to strip them.
DKesserich - 返信 共有
コメントを追加
統計データ:
過去 24時間: 39
過去 7 日: 210
過去 30 日: 638
今までの合計 26,710
