メインコンテンツにスキップ
Staples 34462 Electric Pencil Sharpener A/C Motor Replacement
必要な工具と部品
  1. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement, Cover: 手順 1、 1の画像 1
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 2、 1の画像 1
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 3、 1の画像 1
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 4、 1の画像 1
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 5、 1の画像 1
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 6、 1の画像 1
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 7、 1の画像 1
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement, A/C Motor: 手順 8、 1の画像 1
    • Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
  9. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 9、 1の画像 1
    • Carefully pull apart the gear housing's panels.
    • The gears are lubricated by petroleum jelly.
  10. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 10、 1の画像 1
    • Using a Philips 00 screwdriver, remove the first 10.3mm screw attaching the A/C motor to the panel.
  11. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 11、 1の画像 1
    • Gently pry the gear from the panel with a spudger to expose the second screw holding the electric A/C motor to the panel.
    • To ease reassembly, note the orientation of the gear as you pry it free.
  12. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 12、 1の画像 1
    • Using a Philips 00 screwdriver, remove the second 10.3mm screw securing the electric A/C motor to the panel.
  13. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 13、 1の画像 1
    • Pull out the electric A/C motor from the gear housing panel.
  14. Staples 34462 Electric Pencil Sharpener A/C Motor Replacement: 手順 14、 1の画像 1
    • Using a soldering iron, carefully de-solder the two wires from the electric A/C motor.
    • This step requires soldering. See iFixit's soldering guide for more tips and information.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Brian Eliason
メンバー登録日: 10/27/14
379 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Carnegie Fall 2014 Eastern Washington University, Team 1-5, Carnegie Fall 2014人のメンバー
EWU-CARNEGIE-F14S1G5
7 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,712
