メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sprout Channel Cubby Digitizer Replacement
必要な工具と部品
  1. Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: 手順 1、 2の画像 1 Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: 手順 1、 2の画像 2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
    FixBotに聞いてみる
    コメントを追加
  2. Sprout Channel Cubby Digitizer Replacement, Digitizer: 手順 2、 1の画像 1
    • Once opened, carefully peel back the black electric tape around the digitizer.
    FixBotに聞いてみる
    コメントを追加
  3. Sprout Channel Cubby Digitizer Replacement: 手順 3、 1の画像 1
    • Unclasp the electrical plastic strip by gently pulling up on the white colored clasp.
    FixBotに聞いてみる
    コメントを追加
  4. Sprout Channel Cubby Digitizer Replacement: 手順 4、 1の画像 1
    • Unscrew the five screws holding down the motherboard.
    FixBotに聞いてみる
    コメントを追加
  5. Sprout Channel Cubby Digitizer Replacement: 手順 5、 1の画像 1
    • Once all five screws are removed, you should be able to lift up the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Sprout Channel Cubby Digitizer Replacement: 手順 6、 1の画像 1
    • Remove the four remaining screws.
    • This can be done with the battery still attached but is easier if it is unattached.
    FixBotに聞いてみる
    コメントを追加
  7. Sprout Channel Cubby Digitizer Replacement: 手順 7、 1の画像 1
    • Remove the metal sheet covering the screen and digitizer.
    • Removing the screen is a very fragile process and needs to be done slowly. The nylon spudger is the best tool for this.
    FixBotに聞いてみる
    コメントを追加
  8. Sprout Channel Cubby Digitizer Replacement: 手順 8、 2の画像 1 Sprout Channel Cubby Digitizer Replacement: 手順 8、 2の画像 2
    • Remove all of the white pegs located along the perimeter of the plastic. You'll need to remove all of the pegs to remove the white front face.
    FixBotに聞いてみる
    コメントを追加
  9. Sprout Channel Cubby Digitizer Replacement: 手順 9、 2の画像 1 Sprout Channel Cubby Digitizer Replacement: 手順 9、 2の画像 2
    • To take out the digitizer, remove the connector ribbon from the plastic and then slowly apply pressure to the corner and edges of the digitizer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
David Meyers
メンバー登録日: 08/26/15
244 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015人のメンバー
USFT-MEIER-F15S14G101
4 メンバー
12のガイドは作成済み
4件のガイドコメント
Ok I opened up the back and I accidentally pressed a little on the battery and now my screen is all white no picture. What did I do is there a way to fix the picture?
deysi gallegos - 返信 共有
Most likely the LCD is broken and needs to be replaced.
Stephen Martinez - 返信 共有
You don't need to remove the mother board or the battery from the LCD to replace the digitizer. Once you remove the screws from the motherboard you can lift it up to access the screw for the front bezel and access the bezel clips underneath. Taking the battery off the LCD will most likely damage the LCD, so don't even mess with it. After you have the front bezel removed, flip the entire assembly over and you can replace the digitizer. Make sure you remove all the black foam and adhesive from the case after the digitizer is removed. This makes assembly easier and prevents damage to the new digitizer.
I replaced my digitizer screen and it is still not working, what is the screen under the first screen called and it is still showing a dysfunctional screen
pam - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 4,246
