はじめに
The purpose of this guide to provide simple and straight-forward instruction on replacing a damaged or jammed speed switch.
必要な工具と部品
Use a phillips head screwdriver to unscrew the following 8 screws:
One 24mm Phillips screw
Six 16mm Phillips screws
One 9mm Phillips screw
Turn the drill to the other side and unscrew the marked screw using the same phillips head screwdriver. Place it with the other removed screws.
3 の人々がこのガイドを完成させました。
