メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Xperia ZL Battery Replacement
必要な工具と部品
  1. Sony Xperia ZL Battery Replacement, Battery: 手順 1、 1の画像 1
    • Place the phone face down.
    FixBotに聞いてみる
    コメントを追加
  2. Sony Xperia ZL Battery Replacement: 手順 2、 1の画像 1
    • At the bottom of the phone will be a cover that flips open. A sticker will be under and when the sticker is peeled back, two screws will be revealed. Use a JIS J00 screw head to unscrew.
    FixBotに聞いてみる
    コメントを追加
  3. Sony Xperia ZL Battery Replacement: 手順 3、 1の画像 1
    • Once the two screws have been removed. Take the prying tool to pry off the back cover of the phone. Next take a JIS J00 screwhead and unscrew the 5 screws that are located in the photo.
    FixBotに聞いてみる
    コメントを追加
  4. Sony Xperia ZL Battery Replacement: 手順 4、 1の画像 1
    • After the screws have been taken out, carefully disconnect the 7 indicated connectors using a small plastic opening tool or spudger.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    FixBotに聞いてみる
    コメントを追加
  5. Sony Xperia ZL Battery Replacement: 手順 5、 1の画像 1
    • The last connector is located under the black sticker. Peel back the black sticker and disconnect the last connector.
    FixBotに聞いてみる
    コメントを追加
  6. Sony Xperia ZL Battery Replacement: 手順 6、 1の画像 1
    • Once all the connectors have been disconnected. You will want to use a small prying tool to pry out the back camera and all its components from the phone.
    FixBotに聞いてみる
    コメントを追加
  7. Sony Xperia ZL Battery Replacement: 手順 7、 1の画像 1
    • Remove the electrical panel with a plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  8. Sony Xperia ZL Battery Replacement: 手順 8、 1の画像 1
    • Take a small plastic prying tool and pry out the battery of the phone. The battery has adhesive tape that connects it to the phone which makes it difficult to pry out. Make sure to try prying from different angles of the battery.
    • Use a plastic prying tool when taking out the battery because any puncture within the battery could cause a fire.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Liam Kanaley
メンバー登録日: 11/03/15
433 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 UMass Dartmouth, Team 1-7, Bhusal Fall 2015人のメンバー
UMASSD-BHUSAL-F15S1G7
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 11
過去 30 日: 35
今までの合計 2,109
