はじめに
This guide will replace the rear camera in the Sony Xperia Z1 Compact.
必要な工具と部品
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
ある他の人がこのガイドを完成しました。
