はじめに
With this guide, you will be taking the screen off of the device to locate the camera module. The following steps will explain how to remove the necessary parts in order to remove the camera module located on your screen.
必要な工具と部品
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Flip device upward carefully like you are turning the page of a book.
ある他の人がこのガイドを完成しました。
1件のガイドコメント
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
