メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony NEX-7 Screen Replacement
必要な工具と部品
  1. Sony NEX-7 Screen Replacement, Battery: 手順 1、 2の画像 1 Sony NEX-7 Screen Replacement, Battery: 手順 1、 2の画像 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
    FixBotに聞いてみる
    コメントを追加
  2. Sony NEX-7 Screen Replacement: 手順 2、 1の画像 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
    FixBotに聞いてみる
    コメントを追加
  3. Sony NEX-7 Screen Replacement: 手順 3、 1の画像 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
    FixBotに聞いてみる
    コメントを追加
  4. Sony NEX-7 Screen Replacement, SD card: 手順 4、 1の画像 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
    FixBotに聞いてみる
    コメントを追加
  5. Sony NEX-7 Screen Replacement, Lens: 手順 5、 2の画像 1 Sony NEX-7 Screen Replacement, Lens: 手順 5、 2の画像 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
    FixBotに聞いてみる
    コメントを追加
  6. Sony NEX-7 Screen Replacement, Top and Back Shell: 手順 6、 1の画像 1
    • Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. Sony NEX-7 Screen Replacement: 手順 7、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 7、 2の画像 2
    • Remove the 5/32" #00 screw at the top of the compartment using the Phillips #00 screwdriver.
    • Remove the two 5/32" #00 screws from inside the compartment using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  8. Sony NEX-7 Screen Replacement: 手順 8、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 8、 2の画像 2
    • Close the battery door by pushing it down until it latches shut.
    FixBotに聞いてみる
    コメントを追加
  9. Sony NEX-7 Screen Replacement: 手順 9、 1の画像 1
    • Looking at the left side of the camera, lift open the door that has 'HDMI' written on it.
    • Remove the two visible 5/32" #00 screws using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  10. Sony NEX-7 Screen Replacement: 手順 10、 3の画像 1 Sony NEX-7 Screen Replacement: 手順 10、 3の画像 2 Sony NEX-7 Screen Replacement: 手順 10、 3の画像 3
    • Looking at the back of the camera, press the button with a lightning bolt on it to pop the flash open.
    • Remove the three 5/32" screws from within the flash compartment using the Phillips #00 screwdriver.
    • Close the flash compartment.
    FixBotに聞いてみる
    コメントを追加
  11. Sony NEX-7 Screen Replacement: 手順 11、 1の画像 1
    • The top of the camera is attached by three wires and a ribbon cable. Remove the top slowly and gently!
    • Lift the top of the camera off of the body.
    • Let the top hang to the side so you have room to work with the components inside the device.
    FixBotに聞いてみる
    コメントを追加
  12. Sony NEX-7 Screen Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    • Using tweezers or your fingers, gently remove the blue ribbon cable from the port.
    FixBotに聞いてみる
    コメントを追加
  13. Sony NEX-7 Screen Replacement: 手順 13、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 13、 2の画像 2
    • Place the tips of your tweezers on either side of the red jack.
    • Gently pull the red plug out of the jack.
    • Repeat those steps for the yellow jack and plug.
    • Now that the top is free, place it aside for later.
    FixBotに聞いてみる
    コメントを追加
  14. Sony NEX-7 Screen Replacement: 手順 14、 1の画像 1
    • Lift the LCD screen with your fingers such that the screen is bent slightly away from the camera.
    FixBotに聞いてみる
    コメントを追加
  15. Sony NEX-7 Screen Replacement: 手順 15、 3の画像 1 Sony NEX-7 Screen Replacement: 手順 15、 3の画像 2 Sony NEX-7 Screen Replacement: 手順 15、 3の画像 3
    • Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
    • Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
    • The back panel will be easier to take off if the LCD screen has been extended away from the camera by about 60 degrees.
    • Set the back panel aside.
    FixBotに聞いてみる
    コメントを追加
  16. Sony NEX-7 Screen Replacement, LCD Assembly: 手順 16、 1の画像 1
    • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  17. Sony NEX-7 Screen Replacement: 手順 17、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
    • The 5/32" upper screw
    • The 3/32" lower screw
    FixBotに聞いてみる
    コメントを追加
  18. Sony NEX-7 Screen Replacement: 手順 18、 1の画像 1
    • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  19. Sony NEX-7 Screen Replacement: 手順 19、 1の画像 1
    • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  20. Sony NEX-7 Screen Replacement: 手順 20、 1の画像 1
    この手順で使用する道具:
    • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
    FixBotに聞いてみる
    コメントを追加
  21. Sony NEX-7 Screen Replacement: 手順 21、 1の画像 1
    • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
    FixBotに聞いてみる
    コメントを追加
  22. Sony NEX-7 Screen Replacement: 手順 22、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 22、 2の画像 2
    • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
    • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
    • Pull on the D rings on either side of the camera to start removing the assembly.
    • Once the brackets are cleared from black shell, take them off and set them aside.
    • Continue to remove the screen assembly.
    FixBotに聞いてみる
    コメントを追加
  23. Sony NEX-7 Screen Replacement: 手順 23、 1の画像 1
    • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
    • Unplug the cable by applying tweezers to the tabs on either side of the plug.
    • Set the LCD assembly aside.
    FixBotに聞いてみる
    コメントを追加
  24. Sony NEX-7 Screen Replacement, Screen: 手順 24、 2の画像 1 Sony NEX-7 Screen Replacement, Screen: 手順 24、 2の画像 2
    • Set aside the camera body, top, and back plate and focus on the LCD assembly.
    • Rotate the screen away from the metal bracket.
    FixBotに聞いてみる
    コメントを追加
  25. Sony NEX-7 Screen Replacement: 手順 25、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 25、 2の画像 2
    この手順で使用する道具:
    • Use the tweezers to push the tab near the bottom left corner of the panel to release a plastic cover from the back of the panel.
    FixBotに聞いてみる
    コメントを追加
  26. Sony NEX-7 Screen Replacement: 手順 26、 1の画像 1
    • Turn the assembly around and slide the plastic cover off of the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  27. Sony NEX-7 Screen Replacement: 手順 27、 1の画像 1
    • Remove the four 2/32" #00 screws from the metal bracket using the Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  28. Sony NEX-7 Screen Replacement: 手順 28、 2の画像 1 Sony NEX-7 Screen Replacement: 手順 28、 2の画像 2
    • Remove the screen from the metal panel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jay Miley
メンバー登録日: 04/22/14
5,451 ポイント
13のガイドは作成済み
チーム
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G55
4 メンバー
46のガイドは作成済み
4件のガイドコメント
oh oh - took my nex 7 apart - got to step 28 "Conclusion" an realized I need more steps;
how do I disassemble ( and re-assemble )the "screen" that I have now "removes from the metal panel" ?!?
the part I was hopping to replace is part "LCD Screen Display for Sony nex7" a thin panel, dark gray on one side
and mirror-like on the other.....
Is there another how-to out there somewhere on how to do that ?
or did I order a pert that's to detailed/intricate for a how to series ....
Thanks for any advice
john Grigaitis - 返信 共有
hey,
where can we buy the the new screen. I want to change the old broken screen of my NEX 7 but i don't know where to buy on screen.
Thanks for the informations.
maxence - 返信 共有
A much simpler process for this is to remove the two screws at the bottom of the screen, flip the screen to 90 degrees out from the body, and remove the two screws on the back. Then the top plastic piece can be worked loose and the LCD frame can be removed from the metal bracket.
Reinstallation is a little bit tricky because the plastic piece and the metal back plate much be held in place along with the LCD frame before any of the screws can be reinstalled.
Note that there is a plastic spring piece that clips in the top of the LCD frame, and also a clear/white plastic piece that sits on the light sensor element in the corner of the screen.
Long story short is that the metal LCD hinge does not need to be removed from the body in order to replace the LCD…. so, 4 screws instead of 28.
Paul Chambre - 返信 共有
Much easier 4 screw method here:-
https://www.youtube.com/watch?v=jvOcd8NO...
feenix4eva - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 85
今までの合計 12,410
