メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony NEX-7 Lens Mount Replacement
必要な工具と部品
  1. Sony NEX-7 Lens Mount Replacement, Battery: 手順 1、 2の画像 1 Sony NEX-7 Lens Mount Replacement, Battery: 手順 1、 2の画像 2
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
    FixBotに聞いてみる
    コメントを追加
  2. Sony NEX-7 Lens Mount Replacement: 手順 2、 1の画像 1
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
    FixBotに聞いてみる
    コメントを追加
  3. Sony NEX-7 Lens Mount Replacement: 手順 3、 1の画像 1
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
    FixBotに聞いてみる
    コメントを追加
  4. Sony NEX-7 Lens Mount Replacement, SD card: 手順 4、 1の画像 1
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
    FixBotに聞いてみる
    コメントを追加
  5. Sony NEX-7 Lens Mount Replacement, Lens: 手順 5、 2の画像 1 Sony NEX-7 Lens Mount Replacement, Lens: 手順 5、 2の画像 2
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
    FixBotに聞いてみる
    コメントを追加
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: 手順 6、 1の画像 1
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
    FixBotに聞いてみる
    コメントを追加
  7. Sony NEX-7 Lens Mount Replacement: 手順 7、 1の画像 1
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
    FixBotに聞いてみる
    コメントを追加
  8. Sony NEX-7 Lens Mount Replacement: 手順 8、 1の画像 1
    • Remove the two newly visible #00 screws within the metal ring.
    FixBotに聞いてみる
    コメントを追加
  9. Sony NEX-7 Lens Mount Replacement: 手順 9、 1の画像 1
    • Remove the final metal ring from the mount.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jay Miley
メンバー登録日: 04/22/14
5,453 ポイント
13のガイドは作成済み
チーム
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G55
4 メンバー
46のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 38
今までの合計 3,021
