はじめに
The removal of the motherboard involves removing a significant portion of the rear casing, the internal casing, and the removal of component connections. Care and safe handling is advised in this guide.
必要な工具と部品
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
The removed motherboard and camera body should now appear as shown.
6 の人々がこのガイドを完成させました。
3件のガイドコメント
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
