はじめに
Follow this guide to replace a faulty optical disk drive in your Sony BDP-S360 Blu-Ray player.
The optical disk drive is a piece of hardware responsible for accepting, scanning, and playing CDs, DVDs, and Blu-ray discs. A faulty optical disk drive may produce irregular noise and/or prevent your video player from properly accepting, recognizing, and playing videos/audio.
Before attempting this guide, inspect the disc tray for any dust hampering the component's functionality. Avoid applying cleaning solutions or moisture onto the drive itself. Instead, use an anti-static brush or a can of compressed air to blow out particles. If issues persist, the optical disk drive should be replaced or removed for further inspection. An anti-static wrist strap is encouraged when managing delicate electrical components to reduce the likelihood of electrostatic discharge.
Before beginning, ensure the device is disconnected from a power outlet.
必要な工具と部品
Place the device on a clean solid surface, avoiding wool or cloth surfaces to reduce the likelihood of generating static that may damage hardware.
Use tweezers to pinch the blue tabs and gently pull out the two ribbon cables connected to the right of the optical disk drive.
Use a spudger or tweezers and gently push up on alternating sides of the black locking tab connector connected to the widest ribbon cable before attempting to pull out the cable.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
