メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Alpha NEX-6 Lens Mount Replacement
必要な工具と部品
    1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: 手順 1、 1の画像 1
      • Turn the camera with the lens facing up.
      • Find the lens release button - located along the side of the silver lens mount.
      FixBotに聞いてみる
      コメントを追加
    2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: 手順 2、 2の画像 1 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: 手順 2、 2の画像 2
      • Press and hold the lens release button while rotating the lens counterclockwise.
      • Lift the lens when it is no longer attached to the camera.
      • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
      • Insert the lens and rotate it clockwise until it is locked in place.
      FixBotに聞いてみる
      コメントを追加
    1. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: 手順 3、 1の画像 1
      • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
      • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
      • The outer lens mount ring can now be removed.
      FixBotに聞いてみる
      コメントを追加
    2. Sony Alpha NEX-6 Lens Mount Replacement: 手順 4、 3の画像 1 Sony Alpha NEX-6 Lens Mount Replacement: 手順 4、 3の画像 2 Sony Alpha NEX-6 Lens Mount Replacement: 手順 4、 3の画像 3
      この手順で使用する道具:
      • Pay attention to the positioning of the spacer rings for reassembly.
      • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
      • Repeat this step for the second (silver) spacer ring.
      • The third image is what the camera should look like after all spacer rings are removed.
      FixBotに聞いてみる
      コメントを追加
    3. Sony Alpha NEX-6 Lens Mount Replacement: 手順 5、 2の画像 1 Sony Alpha NEX-6 Lens Mount Replacement: 手順 5、 2の画像 2
      • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Clayton Dale
メンバー登録日: 01/20/15
1,067 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S11G2
4 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 43
今までの合計 2,214
