はじめに
If your Sonos Roam is unresponsive then try this guide to replace the large ribbon.
The large ribbon connects the inner and outer circuit boards. This allows for it to transmit energy and information throughout the device that allows for it to function properly.
Before using this guide, try rebooting your Sonos Roam.
There are steps that recommend (not require) the use of the iOpener. This will help with carefully removing the adhesive used to keep this device together. Refer to this link on how to properly use the iOpener.
必要な工具と部品
Use the metal spudger to pry the end cap with the buttons.
Pry from all sides to loosen the adhesive.
Flip the device so that the Sonos logo is on the top.
Use the Torx T6 screwdriver to remove the two 6 mm screws.
この手順で使用する道具:Tweezers$4.99
Use the tweezers to flip the latch holding the large ribbon in place.
Grab the large ribbon with the tweezers and pull upwards to remove it.
Use the tweezers to flip the latch holding the small ribbon in place.
Grab the small ribbon with the tweezers and pull upwards to remove it.
