はじめに
The 3.7V/3, 200mAh Li-Poly battery is a key component because it stores the power within the device. If it burns out, it must be replaced.
必要な工具と部品
Turn off the device by pressing on the clear power button behind the device.
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
