メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Smart Parts Ion Bolt Replacement
必要な工具と部品
    1. Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 手順 1、 3の画像 1 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 手順 1、 3の画像 2 Smart Parts Ion Bolt Replacement, Hopper and the Air Tank: 手順 1、 3の画像 3
      • Remove the air tank by rotating it counterclockwise.
      • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
      • The pressure gauge will indicate the leftover air in the gun.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 2、 2の画像 1 Smart Parts Ion Bolt Replacement: 手順 2、 2の画像 2
      • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Smart Parts Ion De-Gassing: 手順 3、 1の画像 1
      • Turn the gun on by pressing the power button until the red light blinks.
      • Turn vision mode off by pressing the power button again.
      • Red light should be flashing in a double blink sequence.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 4、 1の画像 1
      • Pull the trigger to release the air in the gun.
      • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Grip: 手順 5、 1の画像 1
      • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 6、 1の画像 1
      • Remove the grip by sliding it towards the front of the gun.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Battery: 手順 7、 2の画像 1 Smart Parts Ion Bolt Replacement, Battery: 手順 7、 2の画像 2
      • Remove the 9V battery by unsnapping it.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 1 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 2 Smart Parts Ion Bolt Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 3
      • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 9、 2の画像 1 Smart Parts Ion Bolt Replacement: 手順 9、 2の画像 2
      • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
      FixBotに聞いてみる
      コメントを追加
    3. Smart Parts Ion Bolt Replacement: 手順 10、 1の画像 1
      • Separate the gun's body from the frame by gently pulling them in opposite directions.
      FixBotに聞いてみる
      コメントを追加
    4. Smart Parts Ion Bolt Replacement: 手順 11、 1の画像 1
      • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Removing the Solenoid from the Body: 手順 12、 1の画像 1
      この手順で使用する道具:
      • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
      • Another small tool or your fingers will work for this.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 13、 1の画像 1
      • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
      FixBotに聞いてみる
      コメントを追加
    3. Smart Parts Ion Bolt Replacement: 手順 14、 1の画像 1
      • Separate the solenoid from the gun's body by gently pulling it upwards.
      FixBotに聞いてみる
      コメントを追加
    4. Smart Parts Ion Bolt Replacement: 手順 15、 1の画像 1
      • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
      FixBotに聞いてみる
      コメントを追加
    1. Smart Parts Ion Bolt Replacement, Bolt: 手順 16、 2の画像 1 Smart Parts Ion Bolt Replacement, Bolt: 手順 16、 2の画像 2
      • Separate the front body breach from the fire chamber by rotating the breach counterclockwise.
      FixBotに聞いてみる
      コメントを追加
    2. Smart Parts Ion Bolt Replacement: 手順 17、 1の画像 1
      • Remove the bolt from the front body breach by gently pulling on the bolt.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Shane Villalpando
メンバー登録日: 02/02/15
1,043 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G42
4 メンバー
40のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 39
今までの合計 3,284
