メインコンテンツにスキップ
Skullcandy Crusher Wireless Bluetooth Antenna Replacement
必要な工具と部品
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: 手順 1、 2の画像 1 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: 手順 1、 2の画像 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 2、 2の画像 1 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 2、 2の画像 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 3、 1の画像 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: 手順 4、 2の画像 1 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: 手順 4、 2の画像 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 5、 3の画像 1 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 5、 3の画像 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 5、 3の画像 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 6、 2の画像 1 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 6、 2の画像 2
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: 手順 7、 1の画像 1
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Val
メンバー登録日: 03/31/22
1,104 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022人のメンバー
UMASSD-GURGEL-S22S1G33
1 メンバー
12のガイドは作成済み
コメント 1 件
Where can one purchase a replacement chip?
Josh - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 51
今までの合計 1,024
