はじめに
Use this guide to replace the battery in a Skullcandy Crusher Wireless headphones. A replacement battery can be bought online.
Follow this replacement guide if you've identified the battery as a source of the problem (or maybe you just want to see the internal components of your Skullcandy Crusher Wireless). To be sure, check out the Troubleshooting page.
Make sure you are not working with a swollen battery.
Also, for more information about soldering and desoldering, please use this guide.
必要な工具と部品
Take your headphones and hold them upside down for better control with your hands.
Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
4 の人々がこのガイドを完成させました。
4 件のコメント
Hi, Can you specify this replacement batterys name and model number?
1050mAh, 3,7V 3,885Wh
Which battery should i buy for my skull candy hes evo??
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
