メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Skateboard Bearing Maintenance
必要な工具と部品
  1. Skateboard Bearing Maintenance, Skateboard Bearing Maintenance: 手順 1、 2の画像 1 Skateboard Bearing Maintenance, Skateboard Bearing Maintenance: 手順 1、 2の画像 2
    • Protect your work area such as a desk with paper towels or newspaper.
    • Be sure that the environment in which you are performing this work is well ventilated and uncarpeted.
    • Remove your bearings from your wheels, if they are not removed already. Please reference the Wheel Installation guide for information on how to properly remove bearings.
    FixBotに聞いてみる
    コメントを追加
  2. Skateboard Bearing Maintenance: 手順 2、 1の画像 1
    • Set out your two metal containers and fill them with just enough of your Citrus Based Cleaner to fully submerge one bearing. One container will be for cleaning and one will be for rinsing.
    • Be sure to wash your hands when finished dealing with the Citrus Based Cleaner as these chemicals can be harsh on skin. Gloves are optional but recommended.
    FixBotに聞いてみる
    コメントを追加
  3. Skateboard Bearing Maintenance: 手順 3、 2の画像 1 Skateboard Bearing Maintenance: 手順 3、 2の画像 2
    • Remove ONE shield from your bearing using the small point of a utility knife. This will allow the chemicals to enter the bearing more freely when the bearing is submerged.
    FixBotに聞いてみる
    コメントを追加
  4. Skateboard Bearing Maintenance: 手順 4、 2の画像 1 Skateboard Bearing Maintenance: 手順 4、 2の画像 2
    • Submerge your bearing in the cleaning container for 15 - 20 seconds to allow the solvent to soak into the bearing.
    FixBotに聞いてみる
    コメントを追加
  5. Skateboard Bearing Maintenance: 手順 5、 2の画像 1 Skateboard Bearing Maintenance: 手順 5、 2の画像 2
    • After submerging the bearing, remove it from the cleaning solution and begin to scrub off any dirt or grease with a toothbrush.
    • You may also scrub the shield that you removed so that it can be cleaned as well.
    FixBotに聞いてみる
    コメントを追加
  6. Skateboard Bearing Maintenance: 手順 6、 3の画像 1 Skateboard Bearing Maintenance: 手順 6、 3の画像 2 Skateboard Bearing Maintenance: 手順 6、 3の画像 3
    • When finished scrubbing the bearing, rinse it in FRESH cleaning solution until there is no dirt or old lubricant in the bearings. Then set this bearing aside.
    • Repeat steps 4 - 7 for your remaining seven bearings. Be sure to continue to refresh your rinsing solution if it becomes too dirty.
    FixBotに聞いてみる
    コメントを追加
  7. Skateboard Bearing Maintenance: 手順 7、 1の画像 1
    • Once you have cleaned all of your bearings, use a can of compressed air to blow any of the cleaning solution out of the bearings.
    • Do this as soon as possible to prevent rust from forming.
    FixBotに聞いてみる
    コメントを追加
  8. Skateboard Bearing Maintenance: 手順 8、 1の画像 1
    • Carefully blot your bearing with a lint-free cloth to remove any excess cleaning solution.
    • Be careful not to get any fibers stuck in the bearing. One tiny piece of hair or lint can severely reduce the performance of your bearing.
    FixBotに聞いてみる
    コメントを追加
  9. Skateboard Bearing Maintenance: 手順 9、 2の画像 1 Skateboard Bearing Maintenance: 手順 9、 2の画像 2
    • After you have thoroughly dried your bearing, you can now relubricate the bearing. To do this, simply coat all inside parts with the lubricant and spin the bearing in order to disperse the lubricant fully.
    • Make sure to spin the bearing immediately after the lubrication process.
    • Warning! The bearing lubricant is harmful if swallowed and can cause skin irritation. Be sure to keep away from open flames because the lubricant is flammable.
    FixBotに聞いてみる
    コメントを追加
  10. Skateboard Bearing Maintenance: 手順 10、 2の画像 1 Skateboard Bearing Maintenance: 手順 10、 2の画像 2
    • Carefully wipe the bearing with a lint-free cloth that is slightly oily. After this you can replace the protective shield by simply pressing it into place.
    • Repeat steps 8 - 7 for all other bearings. After you have completely relubricated all of your bearings, see the Wheel Installation guide to help you install your bearings into your wheels.
    FixBotに聞いてみる
    コメントを追加
終わりに
Cleaning and maintaining your skateboard bearings is crucial to their extended use. This process can be repeated as often as desired by the rider.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Reed Breuer
メンバー登録日: 10/03/12
10 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G32
5 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 37
今までの合計 6,392
